Warning message
Unwanted first digit stripping
Aug 6th, 2013
I'm using a cisco 1751V as ISDN <-> VoIP gateway in conjunction with Asterisk PBX (trunk to trunk)
When Asterisk user dials an outside called number i.e. 0123456789 it is forwarded via SIP trunk to 1751V thus through ISDN BRI card following the dial-peer:
dial-peer voice 10 pots
destination-pattern 0T
port 0/0 (the BRI card)
However, the BRI composed number is 123456789
As 0123456789 is delivered by Asterisk (sip trunk tracing) I suppose Cisco strips someway the first digit , in fact adding another 0 to asterisk dialed string, the call is placed right.
Why and where the first digit is stripped by Cisco ?
How to solve this ??
Thank you
Overall Rating: 5 (1 ratings)
acampbell Tue, 08/06/2013 - 05:36
  • Green, 3000 points or more
Your pots dial peer has
The number in front of the "T" is dropped by default.
To solve your issue rewrtie your dial peer as:-
port 0/0
no digit-strip
Alex.
Please rate useful posts.
