Warning message
subnetting exam question
Answered Question
Aug 6th, 2013
Hi guys, just wondering if someone could correct my answer (not 100% sure I am correct) please
question:
  • GreenEnergy Ltd has been allocated the IP address 199.199.1.0/24 by their ISP. The network administrator for GreenEnergy Ltd.  has decided to split this address space into 16 subnetworks. For this subnetting arrangement, calculate the subnet mask, the valid host range and the broadcast address for the second subnet. Show the workings of your calculations.
(12 marks)
my answer:
original subnet mask = 255.255.255.0
# of subnets: 2(5) = 32 subnets
# hosts: 2(3) -2 = 6 on each subnet
new subnet mask = 255.255.255.248
subnet#networkrangebroadcast
0199.199.1.0199.199.1.1 - 199.199.1.6199.199.1.7
1199.199.1.8199.199.1.9 - 199.199.1.14199.199.1.15
2199.199.1.16199.199.1.17 - 199.199.1.22199.199.1.23
..31
so to answer the question fully:
subnet mask: 255.255.255.248
valid host rage for second subnet (subnet# 1): 199.199.1.9 - 199.199.1.14
boradcast address for second subnet (subnet# 1): 199.199.1.15
Thanks in advance =)
Correct Answer by cadet alain about 4 years 1 week ago
if you need 16 subnets then you will need 4 bits for the subnet so you'll have 24 for the network and 4 more for the subnet which makes a /28 = 255.255.255.240
so the first subnet will be 199.199.1.0/28 and the second one will be 199.199.1.16/28 so valid host range is 199.199.1.17-199.199.1.30 and the broadcast address is 199.199.1.31
Alain
Overall Rating: 5 (3 ratings)
Correct Answer
cadet alain Tue, 08/06/2013 - 13:43
  • Purple, 4500 points or more
Alain
Harold Ritter Tue, 08/06/2013 - 13:44
  • Cisco Employee,
Craig,
A /24 has 256 addresses. If you subdivide as indicated, you get 16 subnets with 16 addresses each.
subnet mask: 255.255.255.240
subnet 0: 199.199.1.0/28 range 199.199.1.1 - 199.199.1.14 broadcast 199.199.1.15
subnet 1: 199.199.1.16/28 range 199.199.1.17 - 199.199.1.30 broadcast 199.199.1.31
subnet 15: 199.199.1.240/28 range 199.199.1.241 -199.199.1.254 broadcast 199.199.1.255
darego1990 Tue, 08/06/2013 - 14:12
so just to make sure i understand subnetting now, i have completed another question. hopefully i got this one correct
  • Tamhlacht Communications Ltd., has been allocated the IP address
192.0.1.0/24 by their ISP. The network administrator for Tamhlacht
Communications Ltd. has decided to split this address space into 4
network address, the valid host range and the broadcast address for
the each subnet. Show the workings of your calculations.
(14 marks)
new subnet mask: 255.255.255.192
subnetnetworkrangebroadcast
0192.0.1.0192.0.1.1 - 192.0.1.62192.0.1.63
1192.0.1.64
192.0.1.65 - 192.0.1.126
192.0.1.127
2192.0.1.128
192.0.1.129 - 192.0.1.190
192.0.1.191
3192.0.1.192
192.0.1.193 - 192.0.1.254
192.0.1.255
thanks again guys
darego1990 Mon, 08/12/2013 - 09:07
Hi again guys, sorry to bump this post but i have 1 last question that i want to make sure is correct, before my exam tomorrow..
this one if different for me because the company does not want a number which of i used to doing like 1, 2, 4, 8, 16... subnetworks they want a number in between (6 on this occasion)
http://gyazo.com/1258864a39c63c2852c901f577d8b7a7.png
my answer so far:
since they want 6 subnets, i must take 4 bits from the subnet which will give 32 hosts per subnet and a subnet mask off 255.255.255.224
0200.200.10.0200.200.10.1 - 200.200.10.30200.200.10.31
1200.200.10.32200.200.10.33 - 200.200.10.62
200.200.10.63
6
200.200.10.160
200.200.10.161 - 200.200.10.190200.200.10.191
is this answer correct? are my ranges and broadcast addresses correct?
darego1990 Mon, 08/12/2013 - 12:46
can anyone tell me if the above question is correct please? exam tomorrow
