Warning message
UCCX agent on a call and a second call comes in
Answered Question
Aug 7th, 2013
  • Bronze, 100 points or more
Not sure if this is a normal behavior but here is what it is happening:
An agent has answered a call from the queue and he is talking to a customer. A second call comes in to his DID number. The phone is ringing as well! I thought a normal behavior would be just a visual indication that there is a second call coming in (light flashing and display indicating the incoming call on the screen) and not ringing the phone.
The phone is configured with only one extension and Ring settings are set to System Default.
Any idea how to change this behavior?
Correct Answer by Chris Deren about 4 years 1 week ago
ACD line should be configured with busy trigger of 1 so second call is not able to be presented to the agent, this is the only supported configuration. If the DID line is separate from ACD line (highly recommended) then the DID line can be configured with higher busy trigger.
HTH,
Chris
Overall Rating: 5 (1 ratings)
Correct Answer
Chris Deren Wed, 08/07/2013 - 07:04
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
HTH,
Chris
Related Content
