Unable to configure ACE 20s
Aug 7th, 2013
I am unable to enter config mode on an active ACE module.
Also, I don't even have the option for any 'sh ft' commands.
It might be an authorization issue with ACS but it doesn't give a 'command authorization fail' message when trying the command.
ACE1/Admin# ?
Exec commands:
  changeto    Changeto another context
  configure   Enter configuration mode
  dir         Directory listing for files
  exit        Exit from the EXEC
  ping        Send echo messages
  show        Show running system information
  ssh         SSH to another system
  terminal    Set terminal line parameters
  traceroute  Trace route to destination
  xml-show    Display xmlized show command result in xml
ACE1/Admin# configure
% invalid command detected at '^' marker.
Does this look like an authorization issue?
Thanks.
Cesar Roque Fri, 08/09/2013 - 15:09
  • Bronze, 100 points or more
Hi Bobby,
The problem is the Role of the user you are using, is probably a network-monitor role. You can check with show users to confirm this.
You probably need to setup the shell attribute in the ACS
Cesar R
ANS Team
Jorge Bejarano Thu, 08/15/2013 - 19:39
  • Silver, 250 points or more
Bob,
If you did not specify a role for your user and password, ACE will take the default which is Network-monitor
Jorge
Related Content
