08-08-2013 04:23 AM
We are building a WAAS lab (not production) for a customer and we recently discovered that we can't use the NME-WAE-502-K9 as the central manager which was very affordable. So we are very disappointed about this. The other equipment are Cisco ISR 2811 (very affordable for building WAAS) with NME-WAE-502-K9 running WAAS 4.1.1 acting as the application accelerators. I have some questions and asking for some advice about some alternative options for us to consider:
Thanks in advanced!
-rya
Solved! Go to Solution.
05-30-2014 08:11 AM
Hi All,
I need to schedule Monthly Traffic Optimization report for 70 WAE devices at a single stretch using WAAS Central Manager. The problem is when i schedule more than 1 device, i just get 1 report and the file name actually has the hostnames of the selected 2 devices separated by comma sign. Instead i would like to have separate report generated for each device. How do i accomplish this?
08-08-2013 04:47 AM
You need a dedicated device for CM. The smallest listed in "Cisco WAAS 5.0 Sizing Guidelines" is 294-4G, which can manage 250 devices.
08-08-2013 11:05 AM
Thank you John. What info are you looking at. I see the lowest end is the Cisco WAVE-274 not the 294?
Based on this link: http://www.cisco.com/en/US/products/ps6474/prod_models_comparison.html
Thank you
-rya
08-09-2013 01:23 AM
Yes you are right. The 294 is the new model, the 274 the older model.
There doesn't really seem to be a really low low-end WAAS device - so for a small test environment I would investigate virtual contral manager (vCM).
John
If this is useful please mark as Helpful or Solved.
09-17-2013 08:04 AM
A central manager is required to managed all of your accelerators properly in a supported configuration. You don't necessarily need a physical appliance though. There is also the virtual form factor (vWAAS is the accelerator version and vCM is the manager version) that can run on a ESXi hypervisor.
http://www.cisco.com/en/US/docs/app_ntwk_services/waas/waas/vwaas/guide/vwaasguide.html#wp69212
John
05-30-2014 08:11 AM
Hi All,
01-12-2014 05:52 AM
You don't need any license for waas devices. They have inbuilt permanent licesnses, you only need to activate the license you need.
There is no ova file available for download for virtual cm, you can only get the ova file through your accounts team which in turn will have to contact cisco PDI team.
