PC's not getting DHCP through Phone+Desktop Smartort role, but Phones are.
Answered Question
Aug 8th, 2013
I'm having a problem and am asking for an extra set of eyes on this one.  We have an old 24-port 2950 non-PoE switch on a floor of a building with separate voice and data vlans.  The ports on the switch I have are set using network assistant with Vlan 512 (voice) and 612 (data).  The phones are grabbing DHCP properly, but the PC's are trying to retain addresses from default vlan 1 and will not grab from vlan 612.  We use a stack of 3750 switches as our core set of switches and does basic static routing, and provides Vlans to other switches via VTP server mode.  On that core stack, I do have the 'ip-helper address' set for the data vlan having problems.  By the time it gets to this closet switch, the connection looks like this:
3750 Stack > 3560 Switch > 2950 Switch.
I ran over there and plugged a laptop in directly to the switch port and I get an address fine on the Data Vlan 612.  If I plug the laptop in through the PC port of the 7945G IP Phone, I don't get an address.  The DHCP scope's appear fine, especially if I get and address.
Where do I check next?
Rory
Correct Answer by Arsen Gharibyan about 4 years 1 week ago
Check VLAN settings in the IP-Phone , some phones are tagging packets that passes thru,if there is any VLAN assighment just turn it off and the packets will be untagged
Correct Answer by jawad-mukhtar about 4 years 1 week ago
Implement these settings for testing in any one port to check if ti works with this settings.
interface tx/x
switchport trunk native vlan 612
switchport mode trunk
switchport voice vlan512
spanning-tree portfast
Jawad
Correct Answer by cadet alain about 4 years 1 week ago
on the 2950 the data vlan is untagged so it is the native vlan when it goes through the trunk to 3750.
Is this the native Vlan on the 3750s ?
Alain
Overall Rating: 5 (3 ratings)
Correct Answer
cadet alain Thu, 08/08/2013 - 09:30
  • Purple, 4500 points or more
Alain
rory.schmitz Thu, 08/08/2013 - 10:16
Thanks for the reply.  They should actually be untagged all the way from the 3750's to the 2950.  Am I correct in stating they are then tagged using the Phone + Desktop smartport role on the 2950?
I use Network Assistant for 99% of the configuration and set Switch Smartport roles with default Vlan 1 for the switch uplinks.  The 3750's and 3560's have the MM Fiber SFP's and the 2950 is uplinked to the 3560 via copper.  Default Vlan 1 is set as the native Vlan for those smarports.
Here is the VTP config for the 2950 and the Port config:
VTP Stat-
Clay4121#sh vtp stat
VTP Version                     : 2
Configuration Revision          : 100
Maximum VLANs supported locally : 250
Number of existing VLANs        : 52
VTP Operating Mode              : Client
VTP Domain Name                 : clayco
VTP Pruning Mode                : Disabled
VTP V2 Mode                     : Disabled
VTP Traps Generation            : Disabled
MD5 digest                      : 0xDB 0x74 0x64 0xBE 0xB2 0xC7 0x81 0x2B
Configuration last modified by 172.25.0.10 at 4-8-11 20:54:50
Interface Config-
interface FastEthernet0/1
switchport access vlan 612
switchport mode access
switchport voice vlan 512
switchport port-security
switchport port-security maximum 2
switchport port-security aging time 2
switchport port-security violation restrict
switchport port-security aging type inactivity
mls qos trust device cisco-phone
mls qos trust cos
auto qos voip cisco-phone
macro description cisco-phone
spanning-tree bpduguard enable
Here's the VTP Status for the Core 3750 Stack:
ClayCore01#sh vtp stat
VTP Version capable             : 1 to 3
VTP version running             : 1
Device ID                       : d48c.b56c.9780
Local updater ID is 172.25.0.10 on interface Vl1 (lowest numbered VLAN interface
found)
Feature VLAN:
VTP Operating Mode                : Server
Maximum VLANs supported locally   : 1005
                                    0xCE 0x7D 0x2F 0x3E 0xE2 0x94 0xB9 0xEF
ClayCore01#
I did notice the VTP versions are different from the core stack and on the 2950.  Maybe that would cause something like this?
Thanks for your help.
Rory
jawad-mukhtar Thu, 08/08/2013 - 13:36
  • Silver, 250 points or more
define ip-helper address under data vlan on all swithes.
***Do Rate Helpful posts***
Jawad
rory.schmitz Thu, 08/08/2013 - 19:17
Hello Jawad,
I have the ip-helper address on data vlan 612 on the core 3750 stack.  I am able to get an address through dhcp when only a PC is plugged into the port, but not when the PC is behind an IP Phone.  In that scenario, the phone is the only device which gets a DHCP address.  I'm using VTP server mode on the core stack, then client mode on the distribution switches to attain the Vlan information.  I've done this many times with our distribution switches and I've never had a problem until now.  Most of our other distributution switches are 3560's and we have just a couple 2950's still in production.  Banging my head on this one...
Thanks for the help.
Rory
Correct Answer
jawad-mukhtar Fri, 08/09/2013 - 10:32
interface tx/x
Jawad
Correct Answer
Arsen Gharibyan Fri, 08/09/2013 - 16:03
rory.schmitz Tue, 08/13/2013 - 06:11
Was away for the weekend, but it appears things are working now.  The VLAN/port settings on the IP-Phones were set to none, or auto, whichever the default was.
Our current port config on the 2950 in question is now this:
interface GigabitEthernet0/1
We previously had it as this:
interface GigabitEthernet0/2
switchport nonegotiate
mls qos trust cos
auto qos voip trust
macro description cisco-switch
spanning-tree link-type point-to-point
I'm not certain why we had to remove most of the config, but it's now working...  We believe it has something to do with upgrading our 3750G Stack to IOS 15.x a few months back.  Before the IOS upgrade, the previous setting would work fine.  Any particular reason in v15.x why this wouldn't work?
Thanks for all of your help.
