Warning message
ASA 5515-X Inspection Engine
Aug 8th, 2013
I'm currently using the Inspection Engine to prevent most users from accessing .zip (and the like) files.  However, this also blocking some websites used during daily business.  I keep getting the following or similar syslog message:
%ASA-4-507003: tcp flow from Inside:X.X.X.X/62401 to External:X.X.X.X/80 terminated by inspection engine, reason - reset unconditionally.
Below is my config:
regex urllist1 ".*\.([Ee][Xx][Ee]|[Cc][Oo][Mm]|[Bb][Aa][Tt]) HTTP/1.[01]"
regex urllist2 ".*\.([Pp][Ii][Ff]|[Vv][Bb][Ss]|[Ww][Ss][Hh]) HTTP/1.[01]"
regex urllist3 ".*\.([Mm][Ss][Ii]) HTTP/1.[01]"
regex urllist4 ".*\.([Zz][Ii][Pp]|[Tt][Aa][Rr]|[Tt][Gg][Zz]) HTTP/1.[01]"
regex applicationheader "application/.*"
regex contenttype "Content-Type"
class-map type regex match-any URLBlockList
match regex urllist1
match regex urllist2
match regex urllist3
match regex urllist4
class-map type inspect http match-all AppHeaderClass
match response header regex contenttype regex applicationheader
class-map type inspect http match-all BlockURLsClass
match request uri regex class URLBlockList
policy-map type inspect http http_inspection_policy
parameters
  protocol-violation action drop-connection
match request method connect
  drop-connection log
class AppHeaderClass
  drop-connection log
class BlockURLsClass
  reset log
policy-map Inside-policy
class Inside-class
Any Ideas?
Robert Garrett Mon, 08/19/2013 - 07:13
  • Cisco Employee,
The problem is not due to the urllists, but rather the regex applicationheader "application/.*"
  drop-connection log
Due to this configuration, on the response, the ASA sees application/xxxxx from nearly all websites and drops the connection.
If this configuration is removed, the problem is no longer seen.
The urllists can also be modified to appropriately block download files by removing HTTP/1.[01] from the string and by placing a space at the end to specify a match at the end of the uri.
-Robert Garrett
Related Content
