Warning message
ARP TIMEOUT
Answered Question
Aug 8th, 2013
How do you show the current arp timeout on router.  I have a 3825 and a 2811.
Thanks in advace.
Alfred
Correct Answer by John Blakley about 4 years 1 week ago
Arp timeout can be found per interface when you do a "show int | i ARP"
Router(config)#do sh int fa0/1 | i ARP
You can change it per interface with the "arp timeout " command on the interface. Default is 4 hours...
HTH,
John
*** Please rate all useful posts ***
Overall Rating: 5 (1 ratings)
Correct Answer
John Blakley Thu, 08/08/2013 - 11:40
  • Purple, 4500 points or more
HTH,
John
