Warning message
7911g stuck in upgrading state after factory reset
Aug 9th, 2013
Hi, I have 2 7911 stuck in upgrading state, no matter if i connect a AC adaptor or by eth, when the 7911 start, show the upgrading windows and stop.
i tried to make another factory reset, but remanins in the same state.
Any idea or software to recover those ipphones?
Thanks!
paolo bevilacqua Fri, 08/09/2013 - 11:25
  • Hall of Fame,
    Founding Member
There are many threas on the subject, please use search function.
ivan aguilar Mon, 08/12/2013 - 05:43
Hi Paolo, my problem is trying to assign a IP to the IPphone, if I try with a SW connected to a router and with wireshark in my Pc I dont see the DHCP offer , and the same problem if I put my Pc as a DHCP Server, but in this case I see the DHCP discover, Rcvd DHCP but after it the message " Supress pingable address" and go looking for in the scope and IP but no one run
Any idea what is happenning?
paolo bevilacqua Mon, 08/12/2013 - 06:02
  • Hall of Fame,
    Founding Member
Something is set wrong in DHCP server, etc.
Gregory Brunn Mon, 08/12/2013 - 06:22
  • Bronze, 100 points or more
Are you running DHCP from the router or CUCM?
Can you post the configuration...
Can you check if another phone gets a dhcp address off the same port.
ivan aguilar Fri, 08/16/2013 - 16:48
Hi, i tried to configure from a router and from my Pc, but both fails.
I tried with other ipphones and the same response.
Does anybody knows a software to make a bootp instead of. DHCP in a ipphone?
Regards!
paolo bevilacqua Sat, 08/17/2013 - 09:56
  • Hall of Fame,
    Founding Member
Phones only use DHCP.
If you configure the server, or router, correctly it will work.
ivan aguilar Mon, 08/19/2013 - 02:52
Hi Paolo again!
My DHCP is running finally properly, now my 7911 has a IP, now I am trying to transfer from my router with CME a firmware, but the phone is still in upgrading state.
I am trying to regiser the phone in the CME but does not run, neither with autoreg nor step by step ephone, ephone-dn and so on...
How can i transfer a firmware to the phone? with the router or with my Pc.
And if the the phone is still in that state, is possible to register in a CME?
thanks!!
paolo bevilacqua Mon, 08/19/2013 - 02:55
  • Hall of Fame,
    Founding Member
As mentioned many times.
CHeck "debug tftp events" with "term mon".
ivan aguilar Sun, 08/25/2013 - 10:55
Finally i resolve this issue.
With a pc connected to switch port in the ipphone, i transfer an IP and firmware with tftpd32. There was not neccesary netiher any router now any switch
thanks.
