Warning message
Connectivity problem with PIX as VPN server
Aug 9th, 2013
I plan on using PIX 515e as VPN concentrator for remote clients to access my dmz network. The config of pix is as follows:
PIX Version 8.0(4)
hostname pixfirewall
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0
nameif outside
security-level 0
ip address xxx.xxx.xxx.xxx 255.255.255.128
interface Ethernet1
no nameif
security-level 100
no ip address
interface Ethernet1.1
description management interface in vlan1
vlan 1
nameif management
security-level 100
ip address 172.30.1.253 255.255.0.0
interface Ethernet1.4
description internal side of office network
vlan 4
nameif office-lan
security-level 100
ip address 192.168.1.253 255.255.254.0
interface Ethernet1.104
vlan 104
nameif office-dmz
security-level 50
ip address 192.168.104.253 255.255.255.0
interface Ethernet2
shutdown
no nameif
no security-level
no ip address
interface Ethernet3
shutdown
no nameif
no security-level
no ip address
interface Ethernet4
shutdown
no nameif
no security-level
no ip address
interface Ethernet5
shutdown
no nameif
no security-level
no ip address
ftp mode passive
access-list 101 extended permit ip any 192.168.0.0 255.255.254.0
access-list dmz-no-nat extended permit ip any 192.168.104.0 255.255.255.0
access-list split-office-dmz standard permit 192.168.104.0 255.255.255.0
pager lines 24
mtu outside 1500
mtu management 1500
mtu office-lan 1500
mtu office-dmz 1500
ip local pool pool-office-dmz 192.168.104.100-192.168.104.200 mask 255.255.255.0
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
nat (office-dmz) 0 access-list dmz-no-nat
route outside 0.0.0.0 0.0.0.0 yyy.yyy.yyy.yyy 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set EzVPN esp-des esp-md5-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map EzVPN-dynmap 5 set transform-set EzVPN
crypto dynamic-map EzVPN-dynmap 5 set security-association lifetime seconds 28800
crypto dynamic-map EzVPN-dynmap 5 set security-association lifetime kilobytes 4608000
crypto map EzVPN-map 60 ipsec-isakmp dynamic EzVPN-dynmap
crypto map EzVPN-map interface outside
crypto isakmp enable outside
crypto isakmp policy 1
authentication pre-share
encryption des
hash md5
group 2
lifetime 86400
crypto isakmp policy 65535
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh 192.168.0.0 255.255.254.0 office-lan
ssh timeout 10
ssh version 2
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
group-policy vpn-office-dmz internal
group-policy vpn-office-dmz attributes
vpn-tunnel-protocol IPSec
split-tunnel-policy tunnelspecified
split-tunnel-network-list value split-office-dmz
vlan 104
tunnel-group tun-office-dmz type remote-access
tunnel-group tun-office-dmz general-attributes
address-pool pool-office-dmz
default-group-policy vpn-office-dmz
tunnel-group tun-office-dmz ipsec-attributes
pre-shared-key *
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
service-policy global_policy global
prompt hostname context
(Username section and external ips omitted in sake of paranoia)
For remote client i use cisco vpn client 5.0.07
Clients can connect just fine, but can't ping office-dmz interface (which i expect should be possible) and pix cant ping remote client (printing "?" - unknown packet type), besides when i see stats on client there is 100 byte increase in recieved traffic for every ping from PIX.
Also for connected client created strange, in my opinion, route:
S    192.168.104.100 255.255.255.255 [1/0] via yyy.yyy.yyy.yyy, outside  (yyy - is default gteway)
When in my opinion it should be like 192.168.104.100 is directly connected, Virtual1234
So the question is is my problem related to ACLs? (can't ping)
Or is it IPSec related? (Unknown packet type may mean that something wrong with decrypting echo_replies on PIX)
Or is in a routing problem? (Strange route to client)
Or is there something else that i'm missing complitly?
Jan Rolny Fri, 08/09/2013 - 12:20
  • Bronze, 100 points or more
Hi Artyom,
is client VPN established correctly?
Regarding ACL's I didn't noticed that your acess-list is applied to any of your interface ip access-group statement) so in this case your access list will not work.
Next crypto isakmp policy 65535 and below is used for other VPN?
Regarding routes applied after VPN establishment seems correct becasou your IP pool for VPN clients is in range 192.168.104.100-192.168.104.200. See line
First VPN client will get 192.168.104.100 IP adress. You should choose IP range which don't conflict with hosts in your network.
Best Regards,
Jan
Artem Mitskiy Fri, 08/09/2013 - 12:50
Hi, Jan
Thanks for your time.
Yes client succesfully establishes connection to PIX and i can't see any errors or warns in debug level logs of a client.
Yeah. i know that) access lists created right now is for disabling nat for client network (dmz-no-acl) and creating split tunneling for client (split-office-dmz) so not appling them to interfaces was a desighn feature) I did not really knoww is pix working on basis "everything that is not restricted is allowed" (and than acls is not a problem here) or "everything that is not allowed is restricted" (and than i simply need to add permitting acls)
policy 65535 was added accordingly to one of the tutorials as "default policy for other cases" but clients never actualy fallthrough to that policy. And besides i've tried to remove it just in case - no luck.
problem with routes is not that address space is shared and there is some conflict. There is logical gap for me because PIX creates next-hop route via it's default gateway for address of a remote client. I can't see any logic here because every vpn client is directly connected to PIX via Virtual interface dedicated to that tunnel.
Jan Rolny Fri, 08/09/2013 - 13:05
by default all traffic is denied on PIX so you need to create and apply appropriate ACL's to permit traffic. Next what I would try is to ping from PC to PC not directly from PIX to PC. Or you can use extended ping and specify source interface. Or you can try packet-tracer.
Also please check logs regarding your ping if you see some bulit outbound connection...
Jan
