Warning message
Iteration in script
Answered Question
Aug 9th, 2013
Does UCCX 8.5 supports while or for loop, if it does then some one can please share syntax of it. Thanks
Correct Answer by Anthony Holloway about 4 years 1 week ago
Yes is does.  In fact, you can type any Java code you want into the editor, you just have to know how to include it.  So for example, if you wanted to loop 10 times, adding each number to the next, and store the output in an int variable:
Do {
  int i;
  for (i = 1; i <= 10; i++) {
    my_num = my_num + i;
This assumes you have a variable called my_num.  You can use Java blocks anywhere in your script where the expression editor exists.
Anthony Holloway
Please use the star ratings to help drive great content to the top of searches.
Overall Rating: 4 (2 ratings)
Correct Answer
Anthony Holloway Fri, 08/09/2013 - 18:13
  • Purple, 4500 points or more
Do {
  int i;
Anthony Holloway
Muhammad Usman Sat, 08/10/2013 - 11:42
Thanks Anthony.. it worked..
Out of curiosity, in Java we can define variable in for loop, like
for(int i=0; i<10; i++)
but here, it was not allowing me, i had to first create int variable and then call that variable in for loop, like you mentioned above, why is it not allowing me to create variable inside for loop?
Anthony Holloway Sun, 08/11/2013 - 21:40
I don't know, but that's exactly why I wrote it that way.  There's some differences between pure Java and UCCX.
Anthony Holloway
Related Content
