Warning message
UCCX upgrading getting name does not match any filter pattern
Endorsed Question
Aug 9th, 2013
                   I am upgrading from UCCX on vm version 8.5.1.11004-25 to version 9.0.2.11001-24 and im getting the invalid upgrade.  Name does not match any filter pattern.   Im not sure what this means.. can someone help me out??  very much appriciated!
Endorsed by Rob Huffman
shane.orr about 4 years 5 days ago
I would try
ciscouccx.refresh_upgrade_v1.2.cop.sgn
Description:ciscouccx.refresh_upgrade_v1.2.cop.sgn - Used for upgrades from Unified CCX 8.x to Unified CCX 9.0(2)
Release:9.0(2)
Release Date:04/Jan/2013
File Name:ciscouccx.refresh_upgrade_v1.2.cop.sgn
Size:42.10 MB (44140305 bytes)
MD5 Checksum:56617505a7899ccab5864a42b9845974
Downloads Home
Products
Voice and Unified Communications
Customer Collaboration
Cisco Unified Contact Center Products
Cisco Unified Contact Center Express
Cisco Unified Contact Center Express 9.0(2)
Customer Response Solution Software-9.0(2)
Overall Rating: 5 (1 ratings)
shane.orr Tue, 08/13/2013 - 03:46
  • Silver, 250 points or more
Is this a physical DVD or mounting the ISO through ESXi?
If it is a physical DVD did you extract the .ISO to the DVD (Burn Image)?  If you just did a straight data copy of the .ISO to the DVD, I do not believe that will work.
You should also be able to SFTP the .ISO however.
This all under the assumption the md5 hash checks out.
matrober Tue, 08/13/2013 - 04:49
  • Cisco Employee,
Hello Nathan,
I would agree with Shane : I'm not sure that copying the ISO file on a DVD (and not burning it as an ISO image) will be sufficient for the application to detect it. But in any case, one question : did you install the file ciscouccx.refresh_upgrade_v1.1.cop.sgn before thrying your upgrade process ? This file is required before the upgrade process can be successful.
Please refer to the release notes here :
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/crs/express_9_0/release/guide/UCCX_BK_U1609442_00_uccx-release-notes.pdf
Here is the link to download the COP file :
http://software.cisco.com/download/release.html?mdfid=284367996&flowid=38622&softwareid=280840578&release=9.0%281%29&relind=AVAILABLE&rellifecycle=&reltype=latest
Kind Regards,
Matthieu
Nathan McKown Tue, 08/13/2013 - 06:58
No, its a VM, so i downloaded the .iso file from my put tool.  I have used the same process upgrading all my other applications by setting the .iso file in my cd/dvd drive in my datastore in my vsphere, and that has worked fine for me.   I did not install the cop file, so i will try that, and see if it works for me.. Thanks for the help, i will post my results..
Nathan McKown Tue, 08/13/2013 - 07:48
I just went to add the cop file and got this error.. i don't see any other cop files for my version! any ideas or does my version not "need" the cop file?
***** ERROR ***** ERROR ***** ERROR ***** ERROR ***** ERROR ***** ERROR ***** ERROR ***** ERROR ***** ERROR *****
Critical error during installation of cop ciscouccx.refresh_upgrade_v1.1.cop
ERROR: This cop file is not applicable to this version (8.5.1.11004-25). This cop file is intended to be installed only on the following versions UCCX 802 SU4 (8.0.2.11005-20) and 851 SU3 (8.5.1.11003-32)
shane.orr Tue, 08/13/2013 - 07:58
I would try
Release:9.0(2)
Downloads Home
Products
matrober Tue, 08/13/2013 - 08:08
  • Cisco Employee,
Yes correct, I was about to propose the same. Sorry for the confusion...
Nathan McKown Tue, 08/13/2013 - 08:35
Thanks for the link.. that cop file worked.. i will try my version upgrade now.. thanks!
