Warning message
Stress testing Application
Aug 10th, 2013
Does Cisco has some utility that i can use to perform stress testing of my UCCX script, before i bring it to production, i have called Restful Web services several times in my script. Thanks
david.macias Sat, 08/10/2013 - 17:59
  • Blue, 1500 points or more
I think there is some service which Cisco sells, but can't remember what it's called.  The big vendor is Empirix, but they are expensvie, but they can do pretty much any type of testing phone lines, data, email, etc.  What I recommend, specially if you're trying to test an application with web services, is maybe increase the amount of calls your application makes and send it multiple calls on your own.  It will never be enough, but it might help a bit.
david
Related Content
