switching oversubscription
Answered Question
Aug 11th, 2013
I have been reading about oversubscription rates in certain documents, but i cant get an exact idea what does it mean.
What exactly does it indicate when we say oversubscription rate is 1:2 or so.
It would be helpful if this can be explained to get the idea.
Thanks in advance
Correct Answer by Reza Sharifi about 4 years 6 days ago
Have a look at table-1 in this link.  Lets look at the 8 port 10Gig module.  The switch fabric connection for the 6500 to this module is at 40Gbps.  If you use all 8 ports at 10Gig speed (line rate) you need an 80Gig switch fabric connection.  So, since you have 40Gbps backplane and 8 port 10Gig, the module is 2:1 over subscribed.
8X10=80 but the switch fabric is 40.
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/product_data_sheet09186a00801dce34.html
Does it make scene?
Overall Rating: 5 (2 ratings)
Correct Answer
Reza Sharifi Sun, 08/11/2013 - 19:34
  • Cisco Designated VIP,
    2017 LAN
Does it make scene?
Joseph W. Doherty Mon, 08/12/2013 - 02:35
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Oversubscription is when it's possible for "offered" bandwidth to exceed "available" bandwidth.  The difference in bandwidths can be compared in a ratio.
For example.
An 8 port FE copper switch with a single FE fiber would be oversubscribed - 8:1 as the 8 copper ports could all want to send 100 Mbps out the switch across the single FE fiber port.  However, if the fiber uplink was gig, then the edge ports would be oversubscribed 10:1, as the single gig fiber port could send to any one copper FE port.
