Warning message
H323 Gateway error - %VOICE_IEC-3-GW: H323: Internal Error
Aug 12th, 2013
We are getting following error and wuld like to know solution for it.
Here is the error message from the Gateway:
%VOICE_IEC-3-GW: H323: Internal Error (H323 Interworking Error): IEC=1.1.127.5.21.0 on callID 14269 GUID=80FC8A6                                        9E6C901202F01C4020A03CA6A
R1#sh voice iec description  1.1.127.5.21.0
    IEC Version: 1
    Entity: 1 (Gateway)
    Category: 127 (interworking (127))
    Subsystem: 5 (H323)
    Error: 21 (H323 Interworking Error)
    Diagnostic Code: 0
R1#show h323 gateway cause-codes
CAUSE CODE STATISTICS AT 18w0d
     DISC CAUSE CODE        FROM OTHER PEER    FROM H323 PEER
   1 unassigned number (1)                0                30
  16 normal call clearing (            3129              3899
  17 user busy (17)                       0                 1
  18 no user response (18)                0                 1
  19 no user answer (19)                  2                 0
  26 non selected user clea               2                 0
  27 destination out of ord               4                12
  28 invalid number (28)                  6                 0
  31 normal unspecified (31              32                15
  38 network out of order (               6                 3
  41 temporary failure (41)               1                 3
102 recovery on timer expi               0                 1
111 protocol error (111)                 3                 0
paolo bevilacqua Mon, 08/12/2013 - 05:29
  • Hall of Fame,
    Founding Member
Update IOS and check again.
