Warning message
Help me to determine actual RAM size in C3750X
Aug 12th, 2013
In my Catalyst 3750X switch show version command display 256MB of RAM. But Cisco network Assistant only dipaly 178MB of RAM.
Also show processes memory shows another result. Can anyone help me?.
show version output
KSW1A001#sh version
Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9-M), Version 12.2(55)SE3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 05-May-11 15:40 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x02800000
ROM: Bootstrap program is C3750E boot loader
BOOTLDR: C3750E Boot Loader (C3750X-HBOOT-M) Version 12.2(53r)SE2, RELEASE SOFTWARE (fc1)
KSW1A001 uptime is 32 weeks, 6 hours, 55 minutes
System restarted at 09:05:48 BST Mon Dec 31 2012
System image file is "flash:/c3750e-universalk9-mz.122-55.SE3/c3750e-universalk9-mz.122-55.SE3.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
License Level: ipbase
License Type: Permanent
Next reload license Level: ipbase
cisco WS-C3750X-48 (PowerPC405) processor (revision A0) with 262144K bytes of memory.
Last reset from power-on
7 Virtual Ethernet interfaces
1 FastEthernet interface
52 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
!output omiitted
Show processes memory output
KSW1A001#sh processes memory sorted
Processor Pool Total:  187685032 Used:   45725896 Free:  141959136
      I/O Pool Total:   16777216 Used:   10527140 Free:    6250076
Driver te Pool Total:    4194304 Used:         40 Free:    4194264
Above result shows its 198.99 MB.
Below picture shows RAm details shown in CNA.
Thanks in advance.
Sreejith
Overall Rating: 5 (3 ratings)
Vignesh Rajendr... Mon, 08/12/2013 - 21:45
  • Cisco Employee,
  • Events Top Contributors,
    Cisco, 2014
Hi Sreejith,
If you need to make precise calculations you need to sum up the "size" values seen in the output of "show region". This total value should more or less match the value that you seen in the output "show version".
The output of "show proc memory sorted" does not involve memory consumed by process which assist IOS image compression/decompression activity and other internal process which are helpful during router/switch bootup.
***********Plz do rate this post if you found it helpful*************************
Thanks & Regards,
Vignesh R P
IT Dept Mon, 08/12/2013 - 22:02
Hi Vignesh,
     Thanks for your reply.
Sreejith
