one way ping router anyconnect
Aug 12th, 2013
there is an issue with my anyconnect.
I have 2801-SEC router and i try to configure an anyconnect remote access VPN.
Client can connect to my router, it obtain IP and everithing good. Client can ping everything in my LAN including local interfaces IP addresses of router. But router can not ping remote client. I think because of this there is no voice through VPN tunnel between cisco router's CME and SIP softphone on my Samsung's IPAD:)
Here is config:
interface Loopback100
ip address 192.168.150.99 255.255.255.0
ip nat inside
ip virtual-reassembly in
interface FastEthernet0/0.1
description TRUNK_TO_DATA_VLAN
bandwidth 20000
encapsulation dot1Q 100
ip address 192.168.100.1 255.255.255.0
ip flow ingress
ip flow egress
ip nat inside
interface FastEthernet0/1
description WAN
ip address **.79.***.78 255.255.255.248
ip flow ingress
ip flow egress
ip nat outside
duplex auto
speed auto
ip nat inside source list SSL interface FastEthernet0/1 overload
ip route 0.0.0.0 0.0.0.0 **.79.***.73
ip access-list extended SSL
permit ip any any
webvpn gateway gateway_1
ip address **.79.***.78 port 443
http-redirect port 80
ssl trustpoint LTK_ROUTER_Certificate
inservice
webvpn install svc flash:/webvpn/anyconnect-win-2.5.3046-k9.pkg sequence 1
webvpn context SSL_LTK
secondary-color white
title-color #669999
text-color black
ssl authenticate verify all
policy group policy_1
   functions svc-enabled
   svc address-pool "SSL_pool"
   svc keep-client-installed
   svc split include 192.168.200.0 255.255.255.0
   svc split include 192.168.100.0 255.255.255.0
default-group-policy policy_1
gateway gateway_1
inservice
end
Thank you for your help
Peter Koltl Sat, 09/14/2013 - 12:49
  • Silver, 250 points or more
  • Community Spotlight Award,
    Member's Choice, March 2016
I think you should add a route-map to NAT to exclude the LAN-to-Anyconnect traffic from NAT.
