08-12-2013 12:20 PM - edited 03-12-2019 05:42 PM
ISE 1.1.1 connected to Active Directory for both Radius auth and Administration auth. I have an internal monitor account and the default internal admin account. When I go to Administration > Admin Access > Authentication > Password Policy and attempt to make any changes I receive the following error:
Error occurred: Unable to save configuration details. Authentication settings could not be saved since the currently configured external source is referred in one or more admin groups.
I assume the error is in regard to using AD to auth an admin group, but I'm not sure why it would interfere with the local password policy of internal users. The AD connected admin group is a new admin group and not from a default existing group.
Thank you for any assistance.
08-13-2013 12:59 AM
Hello Richard
If you have configured an external identity source such as LDAP and want to use that as your |
Every Cisco ISE administrator account is assigned one or more administrative roles. To perform the For more information, this link would be helpful to you: http://www.cisco.com/en/US/docs/security/ise/1.1.1/user_guide/ise_ug.pdf see page no: 148 |
08-13-2013 03:58 AM
Logging in with both internal and external users works just fine. My problem is changing the password policy for local users as noted above. The error occurs when changing said policy.
12-08-2013 10:12 PM
Why not prefer password policies in Google apps ? May it favorably works for you..Try it...It resolve your problem...
09-04-2013 06:21 AM
This is a known bug in ISE 1.1.x
The workaround is the ensure you're local admin account is enabled. Log in with the internal admin account. Then, under your Admin Groups change your external group to be an internal only group. You can then change your password policy and save it. Finally, enable your external admin group.
This is fixed in 1.2
Also, I've searched through the bug list and can't find any reference to this, but was told these instructions by TAC.
