Warning message
SITE TO SITE VPN INITIATION ISSUE
Aug 12th, 2013
Hi All,
We are having trouble with a site to site VPN as follows:
PROBLEM
In this example we will use site A and site B. We have a Pix 515E at site A and a Cisco 1801 at site B with a site to site between the two. If we ping from site B to site A then the tunnel comes up and we can ping in either direction and traffic flows in both directions. If we try to ping from site A to site B to bring up the tunnel then the pings will fail. So, put another way we can only initiate the tunnel from site B.
TROUBLE SHOOTING SO FAR
We have checked the NAT and ACLs, all of which seem fine and seem comparable with other configs on working systems in the field.
Anyone have any suggestions or possible causes?
regards,
fb_webuser Mon, 08/12/2013 - 16:17
  • Silver, 250 points or more
Can you post the configs? Also when behind the 1801, when you try to ping does the tunnel come up? What is showing when you do a show crypto ipsec or isakmp?
Also might try debug crypto ipsec/isakmp and try initialize tunnel. That debug should/would tell you the exact cause. Lastly, are you trying ping from the 1801 to the PIX, or a device behind the PIX?
Posted by WebUser Sean Waite from Cisco Support Community App
tech01cisco Tue, 08/13/2013 - 04:52
Hi All,
Please find answers to questions so far and the config for the 1801.
We can ping from either a PC behind the 1801 or from the 1801 directly, either will bring up the tunnel. Alternatively if we ping from the Pix we can not initiate the tunnel. We have run debug on the 1801 but it shows nothing as it seems the traffic is not getting over the VPN to the 1801. Just to recap; our problem is that we can not initiate the tunnel from the Pix side, only from the 1801 side. Here is the sanitised config:
rt23#sh run
Building configuration...
Current configuration : 6871 bytes
version 12.4
hostname rt23
boot-start-marker
boot-end-marker
logging buffered 52000
enable secret XXXXXXXXXXXXXXXX
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
clock summer-time BST recurring last Sun Mar 2:00 last Sun Oct 2:00
dot11 syslog
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 172.16.99.1 172.16.99.10
ip dhcp excluded-address 172.16.99.240 172.16.99.254
ip dhcp pool LAN23
   network 172.16.99.0 255.255.255.0
   default-router 172.16.99.1
   dns-server 172.16.99.1
   domain-name XXXXX
ip name-server 208.67.220.220
ip name-server 208.67.222.222
ip inspect tcp reassembly queue length 128
ip inspect tcp reassembly timeout 10
ip inspect name myfw cuseeme timeout 3600
ip inspect name myfw ftp timeout 3600
ip inspect name myfw rcmd timeout 3600
ip inspect name myfw realaudio timeout 3600
ip inspect name myfw smtp timeout 3600
ip inspect name myfw tftp timeout 3600
ip inspect name myfw udp timeout 15
ip inspect name myfw h323 timeout 3600
ip inspect name myfw sip
ip inspect name myfw icmp
ip inspect name myfw tcp timeout 3600
ip inspect name myfw http timeout 3600
ip ddns update method ddns
HTTP
  add http://XXXXXXXXXXXXXXXXX
interval maximum 0 0 10 0
interval minimum 0 0 5 0
username XXXXXXXXXXXXXXXXXX
crypto isakmp policy 10
encr 3des
authentication pre-share
group 2
crypto isakmp key XXXXXXXXXXXX hostname ZZZZZZZZZZZZ
crypto isakmp keepalive 20 5
crypto isakmp nat keepalive 20
crypto ipsec transform-set SET23 esp-3des esp-sha-hmac
crypto map MAP23 10 ipsec-isakmp
set peer ZZZZZZZZZZ dynamic
set transform-set SET23
set pfs group2
match address 100
archive
log config
  hidekeys
interface Loopback0
ip address 10.0.0.1 255.255.255.255
interface FastEthernet0
description PPPoE Interface
ip address dhcp
shutdown
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface FastEthernet1
switchport access vlan 10
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface ATM0
description DSL Modem
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
no ip mroute-cache
atm vc-per-vp 128
no atm ilmi-keepalive
pvc 0/38
  no oam-pvc manage
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
dsl operating-mode auto
hold-queue 224 in
interface Vlan1
no ip address
interface Vlan10
ip address 172.16.99.1 255.255.255.0
ip nat inside
ip virtual-reassembly
interface Dialer0
description Virtual DSL Interface
ip ddns update hostname XXXXXXXXX
ip ddns update ddns
ip address negotiated
ip access-group Internet-In in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip inspect myfw out
encapsulation ppp
ip route-cache flow
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname XXXXXXXXX
ppp chap password XXXXXXXXX
ppp pap sent-username XXXXXXXXX
ppp ipcp dns request
crypto map MAP23
crypto ipsec df-bit clear
hold-queue 224 in
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
ip http authentication local
ip http secure-server
ip dns server
ip nat inside source route-map SDM_RMAP_1 interface Dialer0 overload
ip access-list extended Internet-In
permit icmp any any echo-reply
permit tcp any any established
permit udp any any eq bootps
permit udp any any eq bootpc
permit esp any any
permit udp any any eq isakmp
permit gre any any
permit tcp any any eq 2221 log
permit udp host 192.53.103.104 eq ntp any eq ntp
permit udp any any eq domain
permit udp any eq domain any
permit ip host XXXXXXXXXX any log
access-list 100 permit ip 172.16.99.0 0.0.0.255 172.16.0.0 0.0.0.255 log
access-list 101 remark CCP_ACL Category=16
access-list 101 deny   ip 172.16.99.0 0.0.0.255 172.16.0.0 0.0.0.255 log
access-list 101 permit ip 172.16.99.0 0.0.0.255 172.16.0.0 0.0.0.255 log
access-list 101 permit ip 172.16.99.0 0.0.0.255 any
route-map SDM_RMAP_1 permit 1
match ip address 101
control-plane
line con 0
logging synchronous
line aux 0
line vty 0 4
password XXXXXXXX
transport input ssh
ntp update-calendar
ntp server 172.16.0.1 source Vlan10
end
Thanks again,
