Warning message
1751 Router Hang after upgrade IOS
Aug 13th, 2013
Dear Friend,
plz help me i have upgrade IOS on cisco 1751
upgradet version c1700-k9sv8y7-mz.122-15.T14.bin
but problem with Router is hang and Router is Stop on below menstion step kinldy help me
Router#copy tftp flash:
Address or name of remote host [172.16.10.220]?
Source filename [c1700-k9sv8y7-mz.122-15.T14.bin]?
Destination filename [c1700-k9sv8y7-mz.122-15.T14.bin]?
Accessing tftp://172.16.10.220/c1700-k9sv8y7-mz.122-15.T14.bin...
Erase flash: before copying? [confirm]
Erasing the flash filesystem will remove all files! Continue? [confirm]
Erasing device... eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee ...erased
Erase of flash: complete
Loading c1700-k9sv8y7-mz.122-15.T14.bin from 172.16.10.220 (via FastEthernet0):
[OK - 13162668 bytes]
Verifying checksum...  OK (0xE7EE)
13162668 bytes copied in 161.580 secs (81462 bytes/sec)
Router#relo
Router#reload
System configuration has been modified. Save? [yes/no]: y
Building configuration...
[OK]
Proceed with reload? [confirm]
*Mar  1 18:37:26.391: %SYS-5-RELOAD: Reload requested by console. Reload Reason:
Reload Command.
System Bootstrap, Version 12.2(1r)XE1, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/cgi-bin/ibld/view.pl?i=support
Copyright (c) 2001 by cisco Systems, Inc.
C1700 platform with 32768 Kbytes of main memory
program load complete, entry point: 0x80008000, size: 0xc8d7b8
Error : memory requirements exceed available memory
Memory required     : 0x021A7F7C
*** System received a Software forced crash ***
signal= 0x17, code= 0x4, context= 0x0
PC = 0xbaddaddd, Vector = 0xbaddaddd, SP = 0xbaddaddd
*** Machine Check Exception ***
PC = 0xfff16784, Vector = 0x200, SP = 0x81fffe28
Leo Laohoo Tue, 08/13/2013 - 02:32
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
You're trying to load an IOS which your DRAM can't accomodate.
Look for another IOS version which will fit your appliance's DRAM and memory.
afroz khan Tue, 08/13/2013 - 02:45
but i am not able to give any commond on router becoz Router is hang on
this step
cadet alain Tue, 08/13/2013 - 02:45
  • Purple, 4500 points or more
The new IOS needs more RAM to be decompressed, you need 96 MB of RAM for this image.
Alain
afroz khan Tue, 08/13/2013 - 02:48
how can re intall IOS if the router hang on
and Router is not going Rommon mode amd # mode
cadet alain Tue, 08/13/2013 - 02:58
power cycle then go to ROMMON  and use tftpdnld to install a valid image.
alain
afroz khan Tue, 08/13/2013 - 04:09
i have use Ctrl-Break key for the go rommon  mode but its not working
afroz khan Tue, 08/13/2013 - 04:13
cadet alain Tue, 08/13/2013 - 04:17
have you shut it down then unshut( power cycle)  ? before using the ctrl-break ?
Alain
