08-13-2013 05:19 AM - last edited on 03-25-2019 05:30 PM by ciscomoderator
Hi!
My two ACS 5.3 servers are configured to replicate between the primary and the secondary. They stopped replicate for about a month ago and I want to check the logs, but I cannot find any logs that says anything about the replication? Can somebody tell me where they should be?
/Lajja
08-13-2013 08:08 AM
get the support bundles.
08-13-2013 09:53 AM
You need to look into management logs of ACS.
Here are the steps:
acs/acsadmin# acs-config
Escape character is CNTL/D.
Username: xxxx ( GUI ADMIN USERNAME)
Password: xxxx ( GUI ADMIN PASSWORD)
acs/acsadmin(config-acs)# debug-log mgmt level debug
Exit
Show acs-logs filename ACSManagement.log
Note: Once you collect the above fine. Turn off the mgmt logs with this command
debug-log mgmt level warn
~BR
Jatin Katyal
**Do rate helpful posts**
