Warning message
Inbound TCP connection denied from x to y
Answered Question
Aug 13th, 2013
Hi Everyone,
Seeing following logs on ASA:
  Inbound TCP connection denied from x to y flags SYN ACK on interface Net
  Inbound TCP connection denied from x to y flags ACK on interface Net
Does this mean that there is Asymmetric route or missing ACL?
MAhesh
Correct Answer by Julio Carvajal about 4 years 1 week ago
Hello Maheshm
First option Asymmetric routing, use the TCP state-bypass option as a workaround.
Remove the asymetric routing as the real fix
Check my blog at http:laguiadelnetworking.com for further information.
Cheers,
Julio Carvajal Segura
Overall Rating: 5 (1 ratings)
Correct Answer
Julio Carvajal Tue, 08/13/2013 - 10:47
  • Purple, 4500 points or more
Hello Maheshm
Cheers,
mahesh18 Tue, 08/13/2013 - 10:53
Hi Julio,
I tested my applying ACL   so you are correct its Asymmetric routing.
MAhesh
