Warning message
ACS 5.4 - not able to join AD domain
Hi.
I'm having trouble joining the ACS 5.4 to an Windows Server 2012 AD domain.
When I use the Test connection, everything is green.
But when I try to join, I get this error:
Failed During Join [Error while configuring Active Directory: Cannot  open file /var/centrifydc/previous/kset.domain: No such file or  directory due to unexpected configuration or network error.Please try  the --verbose option or run 'adinfo --diag' to diagnose the problem.Join  to domain 'gaasdal.net', zone 'null' failed.]
I have tried to use the adinfo and adcheck cli commands, but I'm not able to use them properly. I always get an error when trying to put in options.
A simple adcheck gives me this, though:
ACS-Malaga/admin# acs troubleshoot adcheck gaasdal.net
This command is only for advanced troubleshooting and may incur a lot of network traffic
Do you want to continue?  (yes/no) yes
OSCHK    : Verify that this is a supported OS                          : Pass
PATCH    : Linux patch check                                           : Pass
PERL     : Verify perl is present and is a good version                : Pass
SAMBA    : Inspecting Samba installation                               : Pass
SPACECHK : Check if there is enough disk space in /var /usr /tmp       : Pass
HOSTNAME : Verify hostname setting                                     : Pass
NSHOSTS  : Check hosts line in /etc/nsswitch.conf                      : Pass
DNSPROBE : Probe DNS server 192.168.100.80                             : Pass
DNSCHECK : Analyze basic health of DNS servers                         : Warning
         : Only one DNS server was found in /etc/resolv.conf.
         : At least one backup DNS server is recommended for
         : enterprise installations.
         : Only one good DNS server was found
         : You might be able to continue but it is likely that you
         : will have problems.
         : Add more good DNS servers into /etc/resolv.conf.
WHATSSH  : Is this an SSH that DirectControl works well with           : Pass
SSH      : SSHD version and configuration                              : Note
         : You are running OpenSSH_5.3p1, CiscoSSL 0.9.8r.1.3.
DOMNAME  : Check that the domain name is reasonable                    : Pass
ADDC     : Find domain controllers in DNS                              : Pass
ADDNS    : DNS lookup of DC kari2012.gaasdal.net                       : Pass
ADPORT   : Port scan of DC kari2012.gaasdal.net                        : Pass
ADDNS    : DNS lookup of DC kari2013.gaasdal.net                       : Pass
ADPORT   : Port scan of DC kari2013.gaasdal.net                        : Pass
GCPORT   : Port scan of GC kari2012.gaasdal.net                        : Pass
GCPORT   : Port scan of GC kari2013.gaasdal.net                        : Pass
ADGC     : Check Global Catalog servers                                : Pass
DCUP     : Check for operational DCs in gaasdal.net                    : Pass
SITEUP   : Check DCs for gaasdal.net in our site                       : Pass
DNSSYM   : Check DNS server symmetry                                   : Pass
ADSITE   : Check that this machine's subnet is in a site known by AD   : Pass
GSITE    : See if we think this is the correct site                    : Pass
TIME     : Check clock synchronization                                 : Pass
ADSYNC   : Check domains all synchronized                              : Pass
1 warning was encountered during check. We recommend checking this before proceeding
I have also tried adding the ACS manually in AD, but no use.
What could be wrong?
Any ideas?
Thank you.
Overall Rating: 5 (1 ratings)
Tarik Admani Tue, 08/13/2013 - 19:40
  • Green, 3000 points or more
Do you have patch 2 installed? Here is the compatibility matrix for ACS 5.4 and AD versions -
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_system/5.4/device_support/sdt54.html#wp71115
Here is the release notes as well -
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_system/5.4/release/notes/acs_54_rn.html#wp257803
To find the patch version it is best to ssh into the appliance and issue a show version.
Tarik Admani
*Please rate helpful posts*
Hi, and thanks for answering.
I'm on version:
Patches :        5-4-0-46-4
Jatin Katyal Wed, 08/14/2013 - 03:50
  • Cisco Employee,
This is a known issue.
CSCuh14898    ACS 5.4 Patch 2 fails to join AD Domain
Description: Customer installed ACS 5.4 with Patch 2,  import the backup from ACS 5.3.  It failed to join the domain.
Got:
Failed During Join [Error while configuring Active Directory: Cannot open file /var/centrifydc/previous/kset.domain: No such file or directory due to unexpected configuration or network error.Please try the --verbose option or run 'adinfo --diag' to diagnose the problem.Join to domain 'unitopr.unitint.test .statefarm.org' ;, zone 'null' failed.
Symptom:
ACS Can not join the domain
Conditions:
ACS 5.4 Patch 2
Workaround:
The workaround suggested to manually remove /var/centrifydc/previous folder completely (rm -rf /var/centrifydc/previous) before trying to adjoin. Don't have the chance to try because customer reimage the box, it works.
More Info:
~BR
Jatin Katyal
**Do rate helpful posts**
Tarik Admani Wed, 08/14/2013 - 12:55
TAC will need to do this for you.
Tarik Admani
jwarmoth78 Tue, 09/17/2013 - 11:28
Same issue on a fresh VM install of ACS 5.4.0.46.4.  Attemtping to joing with domain admin and enterprise admin accounts.  DNS resolution is fine throughout the lab/AD environment.  DC is 2008 R2 SP1
"Failed During Join [Error while configuring Active Directory: Cannot  open file /var/centrifydc/previous/kset.domain: No such file or  directory due to unexpected configuration or network error.Please try  the --verbose option or run 'adinfo --diag' to diagnose the problem.Join  to domain 'nerdlab.local', zone 'null' failed.]"
Cisco ACS VERSION INFORMATION
Version : 5.4.0.46.4
Internal Build ID : B.221
Patches :
5-4-0-46-4
acs01/admin# acs troubleshoot adcheck testlab.local
DNSPROBE : Probe DNS server 192.168.1.131                              : Pass
DOMNAME  : Check that the domain name is reasonable                    : Warning
         : The Active Directory domain name testlab.local may cause
         : resolution problems with the operating system domain
         : name server. We strongly suggest you do not use .local
         : as the last component in your Active Directory domain name.
         : If you must, please see the release notes for your operating
         : system and ensure you have disabled multicast DNS.
ADDNS    : DNS lookup of DC labdc.nerdlab.local                        : Pass
ADPORT   : Port scan of DC labdc.nerdlab.local                         : Pass
GCPORT   : Port scan of GC labdc.nerdlab.local                         : Pass
DCUP     : Check for operational DCs in nerdlab.local                  : Pass
SITEUP   : Check DCs for nerdlab.local in our site                     : Pass
2 warnings were encountered during check. We recommend checking these before proceeding
Marc Rousseau Tue, 10/15/2013 - 04:23
We've got the same problem :
Error while configuring Active Directory: Cannot open file /var/centrifydc/previous/kset.domain: No such file or directory due to unexpected configuration or network error.Please try the --verbose option or run 'adinfo --diag' to diagnose the problem.Join to domain 'our.domain', zone 'null' failed.
Version : 5.4.0.46.3
Patches :
5-4-0-46-3
When running "acs troubleshoot adcheck our.domain" everything is OK
Jatin Katyal Tue, 10/15/2013 - 12:48
  • Cisco Employee,
Since patch 5 is available and as per bug the issue has been addressed in patch 5, please apply it.
~BR
Jatin Katyal
