Warning message
Cisco Jabber with Agent Desktop
Aug 13th, 2013
I see that Jabber for Windows is now supported as an agent endpoint device (in softphone mode) in UCCX 9.0(2), but I'm not sure if I can replace IP Communicator just yet. Our agents currently use deskphones with extension mobility so they can work remotely by logging into their device profile in IP Communicator. As you probably know, this scheme is required due to limitations on line sharing imposed by UCCX 8.5.
As a test, I enabled extension mobility for a Jabber for Windows softphone (e.g. CSFxxxxx), but I could not find any support in the user interface for logging into a profile. Does anyone know if this is possible or if the line sharing restriction does not apply to CSF devices?
