Warning message
New ASA 5505 - inside cannot access outside addresses
Aug 13th, 2013
I was using an old Pix 501, and am having trouble getting the ASA 5505 to send internal traffic to the outside. I originally thought it was the lack of a default gateway, but that seems to be configured (When I try to manually set one up, I get a message it is already there).
My ISP provides me with a static IP address range on the outside, 67.115.92.192/29.  The external GW is 67.115.92.193, and I set the outside interface of my FW to 67.115.92.198
Can't quite figure out how to get internal addresses to properly translate and send to the outside interface.  I've searched these forums, but the only answer I can find is "open a TAC case with Cisco"
I'm using ADSM to configure, but logging into the console gives the following config:
ciscoasa# sho config
: Saved
: Written by enable_15 at 20:04:02.428 UTC Thu Aug 28 2008
: Saved
ASA Version 8.2(5)
hostname ciscoasa
enable password blahblahblah encrypted
passwd blahblahblah encrypted
names
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ip address 67.115.92.198 255.255.255.248
ftp mode passive
pager lines 24
logging enable
logging asdm informational
mtu outside 1500
mtu inside 1500
icmp unreachable rate-limit 1 burst-size 1
asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.1.190-192.168.1.200 inside
dhcpd dns 68.94.156.1 68.94.157.1 interface inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:76ab7ed1cac11d6b62fc57f9ab330c0f
Julio Carvajal Tue, 08/13/2013 - 21:23
  • Purple, 4500 points or more
Hello Vincent,
the .198 is the broadcast address! it cannot be used.
I still do not see the route statement
can you share show route?
Please check your inbox
Check my blog at http:laguiadelnetworking.com for further information.
Cheers,
Julio Carvajal Segura
veleveque1 Thu, 08/15/2013 - 21:29
I changed the interface address and explicitly included a default route.  I can ping the ISP default GW from the ASA, but internal devices on 192.168.1.0/24 still don't seem to get out.  Is the default GW statement correct?  I did not add a trunk stmt to the E0/0 interface yet - would this help?
route outside 0.0.0.0 0.0.0.0 67.115.92.193 1
AND
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ip address 67.115.92.197 255.255.255.248
Julio Carvajal Thu, 08/15/2013 - 21:41
Hello Vicent,
Regarding the trunk: No, that will not help.
Do the following
1) Add the following command
Fixup Protocol ICMP
capture capin interface inside match icmp any host 4.2.2.2
cap capout interface outside match icmp any host 4.2.2.2
2) From an internal machine ping 4.2.2.2
3)Provide me the output of
Show run access-Group
show cap capin
show cap capout
Let me know if you read the message I sent you to our inbox (Repy over there )
Cheers,
veleveque1 Sun, 08/18/2013 - 21:44
Sorry about the delay - this is my home machine so I only work on it after-hours.
Everything looks good based on your advice...
fixup protocol icmp
gave me the message
  INFO Converting fixup protocol icmp to MPF commands
ping to 4.2.2.2 give a reply (very good)
Here are the results of the 3 commands you request:
ciscoasa(config)# show run access-group
ciscoasa(config)# show cap capin
8 packets captured
   1: 22:51:41.303649 802.1Q vlan#1 P0 192.168.1.2 > 4.2.2.2: icmp: echo request
   2: 22:51:41.341321 802.1Q vlan#1 P0 4.2.2.2 > 192.168.1.2: icmp: echo reply
   3: 22:51:42.310912 802.1Q vlan#1 P0 192.168.1.2 > 4.2.2.2: icmp: echo request
   4: 22:51:42.326032 802.1Q vlan#1 P0 4.2.2.2 > 192.168.1.2: icmp: echo reply
   5: 22:51:43.312316 802.1Q vlan#1 P0 192.168.1.2 > 4.2.2.2: icmp: echo request
   6: 22:51:43.327558 802.1Q vlan#1 P0 4.2.2.2 > 192.168.1.2: icmp: echo reply
   7: 22:51:44.313765 802.1Q vlan#1 P0 192.168.1.2 > 4.2.2.2: icmp: echo request
   8: 22:51:44.329038 802.1Q vlan#1 P0 4.2.2.2 > 192.168.1.2: icmp: echo reply
8 packets shown
ciscoasa(config)# show cap capout
8 packets captured
   1: 22:51:41.304122 802.1Q vlan#2 P0 67.115.92.197 > 4.2.2.2: icmp: echo request
   2: 22:51:41.341260 802.1Q vlan#2 P0 4.2.2.2 > 67.115.92.197: icmp: echo reply
   3: 22:51:42.311171 802.1Q vlan#2 P0 67.115.92.197 > 4.2.2.2: icmp: echo request
   4: 22:51:42.326002 802.1Q vlan#2 P0 4.2.2.2 > 67.115.92.197: icmp: echo reply
   5: 22:51:43.312560 802.1Q vlan#2 P0 67.115.92.197 > 4.2.2.2: icmp: echo request
   6: 22:51:43.327512 802.1Q vlan#2 P0 4.2.2.2 > 67.115.92.197: icmp: echo reply
   7: 22:51:44.314009 802.1Q vlan#2 P0 67.115.92.197 > 4.2.2.2: icmp: echo request
   8: 22:51:44.329008 802.1Q vlan#2 P0 4.2.2.2 > 67.115.92.197: icmp: echo reply
8 packets shown
ciscoasa(config)#
I will try a Web site next - previously the DNS UDP traffic wasn't getting through.
Julio Carvajal Sun, 08/18/2013 - 22:42
Hello Vincent,
As you saw traffic is going back and forward now,
Make sure you have a DNS on your computer and try some googling around
Let me know how it goes,
Cheers,
vishaw jasrotia Tue, 08/13/2013 - 21:36
Het Vincent ,
make a default route towards the ISP .
And make
interface Ethernet0/0 as a trunk interface .
Hope this help you
Thanks & regards
Vishaw
Marius Gunnerud Fri, 08/16/2013 - 13:20
  • Red, 2250 points or more
  • Cisco Designated VIP,
    2017 Firewalling
can you ping 4.2.2.2 from the ASA?
have you confirmed that the PC's receive the correct IP addresses and default gateway?  If they are getting a correct IP and default gateway, can you ping the ASA inside interface from the PC's? ( you might have to add permit statements to allow pinging the ASA itself.)
Also, the address 67.115.92.198 is fine 67.115.92.199 is the broadcast address.
