Warning message
Change of ISP
Aug 14th, 2013
Hi all. Cannot see anyway to do this without the mileage. We have a customer with 8-10 sites remotely connected to head office via vpn's.
They have decided to save a few pence by changing ISP's therefore changing ip addresses and also, obviously, adsl connection details.
Is it possible to change the login details for the adsl connection remotely without losing connectivity?
All advice would be appreciated even if it is 'drive safely'
John Blakley Wed, 08/14/2013 - 04:16
  • Purple, 4500 points or more
You could copy their existing config, change the settings, and copy it back over as the startup config and reload. The obvious problem is that it may not work when it comes back up which now means you'll have to go there to get into the router.
HTH,
John
*** Please rate all useful posts ***
mbluemel Wed, 08/14/2013 - 04:20
Hi John.
I should have thought of that as a great option. At least if it didnt work on all of them I would have less sites to visit. I would love something safer but good call.
