Warning message
Can a WLC have multiple SNMP Trap Receivers with the same cummunity string?
Answered Question
Aug 14th, 2013
My Monitoring team want me to send traps to three different trap collectors with the same SNMP Community string.
I have 2106's, 2504, 4400's, 5500's, 7510 all running either version 6 or 7.
Is this possible on a Wireless controller? If so, how?
Correct Answer by George Stefanick about 4 years 4 days ago
Read this from my friends blog ..
http://mrncciew.com/2013/02/14/configuring-snmp-on-wlc/
Also you can configure SNMP trap receiver where WLC can send its snmp trap messages.  Community Name means SNMP trap receiver name & that does not have any significance like snmp community value."
It doesnt appear to have the same significants .. But I havent tested it
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
Overall Rating: 5 (1 ratings)
Erwin Salazar Wed, 08/14/2013 - 09:51
  • Cisco Employee,
Yes, this is certainly possible.  From the WLC perspective just set up the community string you want to use:
http://www.cisco.com/en/US/docs/wireless/controller/7.0MR1/configuration/guide/cg_controller_setting.html#wpmkr1120672
On your trap receivers simply add the same community string and controller IP address.
Cheers,
Erwin
How helpful was I? Don't forget to rate me when you have the chance!
George Stefanick Wed, 08/14/2013 - 09:59
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, October 2015
Another consideration configure trap receiver on the WLC. Add the servers IP addresses collecting the traps and the traps will follow.
ROBERT TILLMAN Wed, 08/14/2013 - 10:00
Here is my confusion. When I add a Trap receiver on the controller, it asks for "Community String" and "IP Address". It will not allow me to have 2 trap receivers with the same community string.
When I setup a template in PI 1.3, it has a field for "Template Name" and "IP address". Template Name must be unique.
When I apply the template to the controller, it takes the template name and puts it as the community string on the controller.
Is the WLC sending the trap with the the text in the community string field as the community string or is it not sending a community string?
Correct Answer
George Stefanick Wed, 08/14/2013 - 10:03
George Stefanick Wed, 08/14/2013 - 10:04
Please respond back with your results. Intertested in hearing ..
Abhishek Abhishek Wed, 08/14/2013 - 10:37
  • Gold, 750 points or more
As per your query i can suggest you the following solution-
Yes, WLC can have multiple SNMP Trap Receivers with the same community string.
Hope this will help you.
ROBERT TILLMAN Wed, 08/14/2013 - 13:04
I created 3 different templates in PI and pushed them out to the WLC's. On the controller the template name is in the field of community string.
I am waiting for my monitoring guy to tell me if he's getting traps on all 3 of his collectors. When I get then info I'll pass it on.
Thanks guys.
ROBERT TILLMAN Thu, 08/15/2013 - 12:10
My monitoring team is reporting that they are getting the traps from the controllers.
It would be very helpful if PI and the WLC would match on their terms and location of things. I think this is the biggest challenge that I have with PI now.
Thanks for your help!!
George Stefanick Thu, 08/15/2013 - 12:52
Excellent .. Thanks for supporting the rating system !
Related Content
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
