SPAN on Multiple Ports
Answered Question
Aug 14th, 2013
On a 3560 or 3750 is it possible to SPAN multiple ports in 1 session to 1 destination port, with both tx and rx packets?  So this:
#monitor session 4 source int f0/2 - 10 both
monitor session 4 dest   int f0/11
I'm able to enter the commands, but when I do a "sh monitor 4"  it says that ingress is disabled.
Correct Answer by devils_advocate about 4 years 2 days ago
Ingress in Lei's example above relates to the destination port, i.e ensures the destination port can only recieve packets and not transmit them so thats perfectly normal.
Correct Answer by Lei Tian about 4 years 2 days ago
works on my 3560. Maybe some code issue.
CORE-SW1#sh ver | i IOS
Cisco IOS Software, C3560 Software (C3560-IPSERVICESK9-M), Version 12.2(58)SE2, RELEASE SOFTWARE (fc1)
CORE-SW1#sh monitor session all
Session 1
Type                   : Local Session
Source Ports           :
    Both               : Fa0/1-20
Destination Ports      : Fa0/21
    Encapsulation      : Native
          Ingress      : Disabled
HTH,
Lei Tian
Overall Rating: 5 (2 ratings)
Correct Answer
Lei Tian Wed, 08/14/2013 - 19:33
  • Cisco Employee,
Session 1
Source Ports           :
    Both               : Fa0/1-20
          Ingress      : Disabled
HTH,
Lei Tian
David Jennings Wed, 08/14/2013 - 19:37
Thanks. Should the ingress be disabled? Trying to capture packets in/out of those interfaces.
Sent from Cisco Technical Support Android App
Correct Answer
devils_advocate Thu, 08/15/2013 - 01:33
  • Gold, 750 points or more
  • Community Spotlight Award,
    Small Business, November 2015
paul driver Thu, 08/15/2013 - 03:23
  • Green, 3000 points or more
For a normal span session - the answer YES the ingress function should be disabled.
You enable ingress forwarding to accept traffic into that port say to allow for a device like a IDS/IPS to analyse the mirrored traffic.
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
