Warning message
Serial control of Profile monitors
Answered Question
Aug 14th, 2013
Hello!
I've had this question asked of me a few times in the last month.  Integrators are asking for the API commands for the monitors that come with Profile systems, primarily for on/off.  I have been told in the past that the monitors that come with the Profile systems are special for Cisco and are not controllable serially.  I just want to make sure I'm telling people the right thing.
Also, they ask me who is the monitor manufacturer?
Thanks!
Correct Answer by Dharmesh Nandoria about 4 years 6 days ago
Hi Bob,
Yes, You are right these are specially designed monitors for profile system .
You can use following commnad from codec to switch off / on ( standby mode).
xcommand Standby Activate
OK
*r ActivateResult (status=OK):
** end
xcommand Standby deActivate
OK
*r DeactivateResult (status=OK):
** end
There is a serial port on the display which is used for diagnostic purpose, There is a tool call TM control used for it .
If you need this toll let me know I can send you .
hth
Kind regards,
Dharmmesh
Overall Rating: 5 (1 ratings)
Correct Answer
Dharmesh Nandoria Wed, 08/14/2013 - 21:05
  • Cisco Employee,
Hi Bob,
OK
** end
OK
** end
hth
Kind regards,
Dharmmesh
Bob Fitzgerald Thu, 08/15/2013 - 08:56
Hi Dharmesh,
Thank you for the confirmation.  And yes please, that tool may come in handy at some point.  If there are any instructions for the tool, please send those as well.
Thanks!
