Warning message
ONE WAY INITIATION PROBLEM ON IPSEC VPN
Answered Question
Aug 14th, 2013
Hi all,
We are posting this question again as when we tried to edit the original question I think it got deleted... Also, this time with the configuration causing the issue.
PROBLEM
In this example we will use site A and site B. We have a Pix 515E at site A and a Cisco 1801 at site B with a site to site between the two. If we ping from site B to site A then the tunnel comes up and we can ping in either direction and traffic flows in both directions. If we try to ping from site A to site B to bring up the tunnel then the pings will fail. So, put another way we can only initiate the tunnel from site B.
TROUBLE SHOOTING SO FAR
We have checked the NAT and ACLs, all of which seem fine and seem comparable with other configs on working systems in the field.
rt23#sh run
Building configuration...
Current configuration : 6871 bytes
version 12.4
hostname rt23
boot-start-marker
boot-end-marker
logging buffered 52000
enable secret XXXXXXXXXXXXXXXX
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
clock summer-time BST recurring last Sun Mar 2:00 last Sun Oct 2:00
dot11 syslog
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 172.16.99.1 172.16.99.10
ip dhcp excluded-address 172.16.99.240 172.16.99.254
ip dhcp pool LAN23
   network 172.16.99.0 255.255.255.0
   default-router 172.16.99.1
   dns-server 172.16.99.1
   domain-name XXXXX
ip name-server 208.67.220.220
ip name-server 208.67.222.222
ip inspect tcp reassembly queue length 128
ip inspect tcp reassembly timeout 10
ip inspect name myfw cuseeme timeout 3600
ip inspect name myfw ftp timeout 3600
ip inspect name myfw rcmd timeout 3600
ip inspect name myfw realaudio timeout 3600
ip inspect name myfw smtp timeout 3600
ip inspect name myfw tftp timeout 3600
ip inspect name myfw udp timeout 15
ip inspect name myfw h323 timeout 3600
ip inspect name myfw sip
ip inspect name myfw icmp
ip inspect name myfw tcp timeout 3600
ip inspect name myfw http timeout 3600
ip ddns update method ddns
HTTP
  add http://XXXXXXXXXXXXXXXXX
interval maximum 0 0 10 0
interval minimum 0 0 5 0
username XXXXXXXXXXXXXXXXXX
crypto isakmp policy 10
encr 3des
authentication pre-share
group 2
crypto isakmp key XXXXXXXXXXXX hostname ZZZZZZZZZZZZ
crypto isakmp keepalive 20 5
crypto isakmp nat keepalive 20
crypto ipsec transform-set SET23 esp-3des esp-sha-hmac
crypto map MAP23 10 ipsec-isakmp
set peer ZZZZZZZZZZ dynamic
set transform-set SET23
set pfs group2
match address 100
archive
log config
  hidekeys
interface Loopback0
ip address 10.0.0.1 255.255.255.255
interface FastEthernet0
description PPPoE Interface
ip address dhcp
shutdown
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface FastEthernet1
switchport access vlan 10
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface ATM0
description DSL Modem
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
no ip mroute-cache
atm vc-per-vp 128
no atm ilmi-keepalive
pvc 0/38
  no oam-pvc manage
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
dsl operating-mode auto
hold-queue 224 in
interface Vlan1
no ip address
interface Vlan10
ip address 172.16.99.1 255.255.255.0
ip nat inside
ip virtual-reassembly
interface Dialer0
description Virtual DSL Interface
ip ddns update hostname XXXXXXXXX
ip ddns update ddns
ip address negotiated
ip access-group Internet-In in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip inspect myfw out
encapsulation ppp
ip route-cache flow
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname XXXXXXXXX
ppp chap password XXXXXXXXX
ppp pap sent-username XXXXXXXXX
ppp ipcp dns request
crypto map MAP23
crypto ipsec df-bit clear
hold-queue 224 in
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
ip http authentication local
ip http secure-server
ip dns server
ip nat inside source route-map SDM_RMAP_1 interface Dialer0 overload
ip access-list extended Internet-In
permit icmp any any echo-reply
permit tcp any any established
permit udp any any eq bootps
permit udp any any eq bootpc
permit esp any any
permit udp any any eq isakmp
permit gre any any
permit tcp any any eq 2221 log
permit udp host 192.53.103.104 eq ntp any eq ntp
permit udp any any eq domain
permit udp any eq domain any
permit ip host XXXXXXXXXX any log
access-list 100 permit ip 172.16.99.0 0.0.0.255 172.16.0.0 0.0.0.255 log
access-list 101 remark CCP_ACL Category=16
access-list 101 deny   ip 172.16.99.0 0.0.0.255 172.16.0.0 0.0.0.255 log
access-list 101 permit ip 172.16.99.0 0.0.0.255 any
route-map SDM_RMAP_1 permit 1
match ip address 101
control-plane
line con 0
logging synchronous
line aux 0
line vty 0 4
password XXXXXXXX
transport input ssh
ntp update-calendar
ntp server 172.16.0.1 source Vlan10
end
Thanks again,
Correct Answer by Julio Carvajal about 4 years 1 day ago
Can you share the configuration with the domain-name mapping instead of IP addresses?
Check my blog at http:laguiadelnetworking.com for further information.
Cheers,
Julio Carvajal Segura
Overall Rating: 5 (1 ratings)
Julio Carvajal Wed, 08/14/2013 - 21:00
  • Purple, 4500 points or more
I can see that the IP address is dynamically obtained on the Router side correct?
If this is the case then that's expected as the other side will never know what's the IP address of the other Peer,
This is a regular dynamic to static scenario which tell's us that.
Please check this link on my personal blog as that's exactly what you are looking for:
http://www.laguiadelnetworking.com/vpn-tunnel-dynamic-to-static-router-to-asa/
Cheers,
tech01cisco Sat, 08/17/2013 - 09:57
Hi Julio,
Thank you for your input. Just to clarify that the 1801 has a static IP address and Pix has the Dynamic address. However for testing we have set the peers as IP addresses rather than a domain name. I have included the output from "debug crypto isakmp" taken from the Pix. We have checked and checked again the configuration and there are absolutely no mismatches. Once the tunnel is up, initiated from the 1801 only traffic flows fine in both directions.
We reviewed your posting which was in effect our setup in reverse.
Any more suggestions?
88.88.88.88 replaces the real peer address of 1801..
Aug 17 17:25:46 [IKEv1]: IP = 88.88.88.88, Removing peer from peer table failed, no match!
Aug 17 17:25:46 [IKEv1]: IP = 88.88.88.88, Error: Unable to remove PeerTblEntry
Aug 17 17:25:47 [IKEv1]: IP = 88.88.88.88, Information Exchange processing failed
Correct Answer
Julio Carvajal Sat, 08/17/2013 - 10:16
Cheers,
tech01cisco Sat, 08/17/2013 - 10:31
Hi Julio,
Which configuration do you want us to post? The 1801 config is listed above.. Not sure what you mean by domain-name mapping ?? Do you mean the peer domain names?
regards,
Richard Burts Sun, 08/18/2013 - 04:47
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
I am interested in this line in the config
I have not used the parameter for dynamic and am not very familiar with it. But it suggests that it is being set up with a peer in a situation where the address will be learned dynamically. And I agree with Julio that the expected behavior when one peer is learning its address dynamically is that the tunnel is initiated from the peer whose address is dynamic and not initiated from the peer with the static address.
Rick
tech01cisco Mon, 08/19/2013 - 03:41
Hi All,
OK, we have now sorted this problem out and would like to share the results of our investigation and fix with you all.
The problem was on the router (1801) that has the static IP address, the Pix end unusually has a dynamic IP address, not our preferred set up but that's the way the customer has it set up. As Julio pointed out it is possible to set up a tunnel between ASA and router where one is dynamic and the other is static, albeit that this is usually done with the ASA on static and the remote office router dynamic. On the router side we set the peer towards a ddns entry, for example 123.ddns.com whereas on the ASA we had to use the actual IP address of the remote router, which is static in any event. When we tried to initiate a tunnel from the Pix end it saw a mismatch in the ISAKMP phase 1 policy and therefore did not establish. However, and interestingly, we could establish ISAKMP from the router end. We cannot set the ddns name on the Pix as it is my understanding that ASA/Pix cannot resolve TLDs. We use a dynamic DNS entry which is then resolved by NO-IP which helps to cut costs for customers by not having static IPs that are being charged at around £20 a month by many ISPs now. Although not what we wanted to do we had to manually set the IP address on both ends and it worked just fine. We may need to get the customer to pay for static IPs both ends.
So, does anyone know of a workaround that would allow us to use the dynamic IP on the ASA/Pix side at static on the router end??
Thank you to you all for input I have given the correct answer to Julio as his suggestion and link to configuration was whet led us to find the problem.
