Warning message
CNA 5.8.7 can't reset authentication after "authentication failed"
Aug 14th, 2013
I have had a successful setp up of a community in CNA 5.8.7.  I went to include another new device (add to community) that had a different authentication than all the other community switches.  In adding the device I added by attempting with wrong credentials and got the "authentication failed" for the right reason.  When I discovered the correct credentials I again attempted to re-add the device and I keep getting "authentication failed" without the opportunity to reauthentciate with my newly discovered credentials.  An authentication loop is occuring without me being able to correct it.
sriachan Fri, 08/16/2013 - 04:30
Hi Anthony,
   I have tried to reproduce the issue like what you have explained in issue description. CNA working fine to me.
Could you please verify device credentials once again and check wheather http/https are enabled on the device or not?
  Please let me know your comments on this.
Thank you
Srikanth Achanta
Efrat Noy Mon, 08/19/2013 - 09:35
  • Cisco Employee,
Hi Anthony,
Thank you for bringing this to our attention.
We were able to reproduce this issue, and find a fix for it. This would be applied in the next CNA release, which is planned for the end of the month.
Efrat
Related Content
