How to connect Mitel sx2000 pbx to a cisco router using vwic2-2mft-t1/e1
melgalhud
Hello All,
I would like to connect a 2911 cisco router to sx2000 pbx using vwic2-2mft-t1/e1 card. The signaling protocol is used in sx2000 is DPNSS.
The cisco router has E1 card, and the card is configured like this:
isdn switch-type primary-dpnss
controller E1 0/3/0
framing NO-CRC4
clock source internal
pri-group timeslots 1-4,16
interface Serial0/3/0:15
no ip address
encapsulation hdlc
shutdown
isdn incoming-voice voice
isdn dpnss pbxA
no cdp enable
when I do this command
#sh controllers E1
E1 0/3/0 is up.
  Applique type is Channelized E1 - balanced
  No alarms detected.
  alarm-trigger is not set
  Version info Firmware: 20100222, FPGA: 13, spm_count = 0
  Framing is NO-CRC4, Line Code is HDB3, Clock Source is Internal.
  Data in current interval (245 seconds elapsed):
     0 Line Code Violations, 0 Path Code Violations
     4 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     4 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Total Data (last 24 hours)
     0 Line Code Violations, 0 Path Code Violations,
     1652 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
     1652 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
But I still I can not make any calls between the pbx and cisco router.
I confirmed that no-crc4 is used in the pbx and when changed I go the E1 status down.
Any suggestion or help would be appriciated?
paolo bevilacqua
Wrong forum, post in "IP telephony". You can move your post using the actions panel on the right.
