Warning message
CUCM 9.1.1 and AXL getUser
Aug 15th, 2013
Trying to find a AXL call that will return the UC Service Profile for particular users.  The enduser DB has the fkucserviceprofile column, but the getUser AXL call does not return that column or the isLocalUser column.  Is there a AXL call that returns this information for a specific user? Or do I need to create a custom query?
dkartio20 Tue, 08/20/2013 - 12:23
Ok solved this.  The API version needs to be added in multiple areas.  Below is the Java code that creates the call
        // Setting SOAPAction header line
        MimeHeaders headers = soapMessage.getMimeHeaders();
        headers.addHeader("SOAPAction", "CUCM: DB ver=9.0 getUser" );
        SOAPEnvelope envelope = soapMessage.getSOAPPart().getEnvelope();
        envelope.addAttribute(envelope.createName("xmlns:xsd"), "http://www.w3.org/2001/XMLSchema");
        envelope.addAttribute(envelope.createName("xmlns:xsi"), "http://www.w3.org/2001/XMLSchema-instance");
        SOAPBody bdy = envelope.getBody();
        SOAPBodyElement bodyElement = bdy.addBodyElement(envelope.createName(cmdName));
        bodyElement.addAttribute(envelope.createName("xmlns:axl"), "http://www.cisco.com/AXL/API/9.0");
        bodyElement.addAttribute(envelope.createName("sequence"), "1");
