Warning message
Recommendation for gigabit and ipsec router
Aug 15th, 2013
What router would you recommend for the following requirements?
Terminate 2 MM fiber one-gigabit ethernet LAN interfaces
Terminate 1 copper one-gigabit metro ethernet WAN circuit facing network A - neighboring using eigrp
Terminate 1 copper one-gigabit metro ethernet WAN circuit facing network B - neighboring using bgp
---DMVPN HUB on this interface for 20+ sites (aes 256) - running eigrp over the hub
Terminate 1 copper one-gigabit etherate WAN (speed never greater than 45Mbs)
--- DMVPN HUB on this interface for 2 sites (aes 256) - running eigrp over the hub
Presumable it will be an ASR of some flavor but I don't want to over spend our dollars.
Thanks for any input.
Overall Rating: 5 (2 ratings)
Leo Laohoo Thu, 08/15/2013 - 18:28
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
What is your total WAN speed envisioned?
Tod Larson Fri, 08/16/2013 - 05:47
I expect sustained 500Mbps of data replication type traffic on network A.
I expect not more than 100Mbps of sustained traffic on network B.
Both A and B networks back each other up.
Joseph W. Doherty Fri, 08/16/2013 - 08:28
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
If your total aggregate bandwidth is 600 Mbps, you might get by with a 3945E or the new 4451-X might be "just right".
PS:
For interfaces, instead of adding Ethernet interfaces to the router, you might consider Ethernet port expansion via a switch.  (For example a port-channel VLAN trunk between the router and the switch.)
Leo Laohoo Sat, 08/17/2013 - 17:31
  • Hall of Fame,
    2017 LAN, Wireless
As what everyone's saying, ASR 1000 can support up to 1 Gbps (per chassis).  Do you plan, in the next 5 years, to upgrade your WAN speed to 1 Gbps each?  If yes, then think about the ASR 1002-X since you can upgrade the appliance's capabilities, Cisco's "pay as you grow" concept.
Related Content
