License upgrade: IVR ports?
Aug 15th, 2013
We have 10 enhanced agents today, which comes with 300 IVR ports.  We use the system heavily as an IVR, but do also have a small call center using those 10 agent licenses.  We want to move from enhanced to premium licensing so we can do database integration.  But when we do that, would our IVR port count drop down to 20?  That's not an option for us, due to our heavy IVR use.  Would we need to license additional IVR ports separately?
Bill
Tanner Ezell Thu, 08/15/2013 - 19:36
  • Silver, 250 points or more
Hey Bill,
If you upgrade to premium licenses you will lose the 300 ports and there is no way to purchase purely port licenses unless you have IPIVR which has a different type of licensing.
Moving to premium as you suggest will entitle you to 2x the number of agent licenses up to the platform maximum. As you might imagine this could be quite costly.
Your cheapest option is to build a middlewear that works via an HTTP Interface.
Tanner Ezell
www.ctilogic.com
Anthony Holloway Fri, 08/16/2013 - 08:04
  • Purple, 4500 points or more
Tanner is absolutely correct on what would happen to your ports.  For that matter, you were correct in your assumption that it would drop to 20.  Spot on.
I did want to link you to a lengthy discussion over port and licensing I had on the forum recenty.  There's some good information in there and I hope you find it useful.
https://supportforums.cisco.com/message/3998035#3998035
Anthony Holloway
Please use the star ratings to help drive great content to the top of searches.
