Warning message
SPA3102 configuration help
Aug 16th, 2013
Ok so for a bit of scenario background my setup is as follows:
Phone line wall socket------> SPA3102(1)------>NetgearN300(1)---->NetgearN300(2)​---->SPA3102(2)------> analogue handset
-Im experimenting locally with the intention of extending this sytem over a public satellite based internet link between the 2 netgear units however just for the purpose of testing the two netgears are connected via the network 192.168.1.0
-The network between spa 1 and netgear 1 is 10.0.0.0
-The network between spa 2 and netgear 2 is 20.0.0.0
So with that said i am using the following configuration in spa 1:
PSTN Line Tab Line Enable: YES
NAT Mapping Enable: no
NAT Keep Alive Enable: no Register: No
Make Call Without Reg: Yes
Ans Call Without Reg: Yes
UserID: spaone
VoIP-To-PSTN Gateway Enable: yes
VoIP Caller Auth Method: none
VoIP Default DP: 2
VoIP Caller Default DP: none
PSTN-To-VoIP Gateway Enable: yes
PSTN Caller Auth Method: none
PSTN Ring Thru Line 1: no
PSTN Caller Default DP: 2
Dial Plan 2: (S0<:[email protected]: 5061> )
VoIP Answer Delay: 0
PSTN Answer Delay: 2
Line-In-Use Voltage: 12
Line 1 Tab
Enable IP Dialing: YES
...And this configuration in SPA2
Line Enable: Yes
Register: No
UserID: spatwo
DialPlan: (S0<:[email protected]:5060> )
On both routers I am also forwarding ports 5060-5061 and 16384-16492 to the corresponding SPA units.
so.... i have had this configuration working with 2 SPA units on the same network but cant figure out where im going wrong here. Currently all i get is a beeping tone on the handset, no dial tone and what appears to be no connection.
Any help would be great
Ian
