Warning message
l2tp over ipsec asa 5505 %ASA-6-110003 error
Answered Question
Aug 16th, 2013
First of all, apologies for my lack of awareness. It's hard managing Cisco routers when you are newbie. I am learning Cisco as far as I can.
My issue is that I'm trying to setup a l2tp over ipsec vpn connection in my company in order to provide a secure connection however I was not successfully so far. By the time I establish a connection from my home I get this info from ASA:
> show crypto isakmp sa:
4   IKE Peer: 188.76.164.162
    Type    : user            Role    : responder
    Rekey   : no              State   : MM_WAIT_MSG3
> Log Viewer
6          Aug 16 2013          14:11:14          110003          87.216.165.41          500          188.76.164.162          500          Routing failed to locate next hop for UDP from identity:87.216.165.41/500 to outside:188.76.164.162/500
Clientes SO: Windows 7/8 (Services: IKE and AutIP IPSec and IPsec Policy Ageng enabled as well, firewall windows off)
I've tried to find out what’s is wrong making search on google and forums however I couldn’t find the solution.
Attached is my running config.
any help is more than wellcome
Best,
Antonio
Correct Answer by malshbou about 4 years 3 days ago
Hi Antonio,
It is a routing problem in your ASA.
route outside-other 0.0.0.0 0.0.0.0 192.168.4.1 100
route outside-backup 0.0.0.0 0.0.0.0 192.168.0.1 200
But you terminate the VPN at the outside interface (pppoe) which doesn't have a default route to send traffic back to the L2TP client.
Rule of thumb: Have a default route at the same interface where you terminate remote-access VPN.
To make the test from (188.76.164.162) work, you can add the following route:
route outside 188.76.164.162 255.255.255.255 87.216.40.1  1
But such specific route will not be a solution if you expect vpn users to come from different locations. A default route is needed or alternatively you may move the crypto map to the interface which has the default route.
Regards.
Mashal Alshboul
Overall Rating: 5 (1 ratings)
Correct Answer
malshbou Fri, 08/16/2013 - 09:55
  • Cisco Employee,
Hi Antonio,
Regards.
Mashal Alshboul
Related Content
