Cisco 1240ag
Answered Question
Aug 16th, 2013
  • Gold, 750 points or more
  • Participante Destacado,
    El Favorito: Noviembre 2015
Hello everyone... again me.
I really sorry boring you but I would like to know if anyone have ever get this log:
%DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station Reason: Previous authentication no longer valid
The clients can not get connection
Thanks!!
Correct Answer by EvaldasOu about 4 years 1 day ago
You got this error because there is no response from the client. Does it happens on 2.4 or 5 GHz band?
Use "no dot11 extension aironet" on radio1 too.
Otherwise check this:
debug dot11 events
debug dot11 packet
and show us more log messages , please
Overall Rating: 5 (1 ratings)
Daniel Ordonez Fri, 08/16/2013 - 09:10
I did but Still does not working. Here my configuration:
sh run
Building configuration...
Current configuration : 2839 bytes
version 12.3
no service pad
service password-encryption
hostname ap
enable secret 5 $1$XyIP$zv.VE6.tqUKd3WwULNa.r1
ip subnet-zero
ip dhcp excluded-address 195.101.60.1 195.101.60.12
ip dhcp pool 0
   domain-name global.com
   default-router 195.101.60.2
   lease 1 5 36
no aaa new-model
dot11 ssid CISCO_AP
   vlan 10
   authentication open
   guest-mode
power inline negotiation prestandard source
username Cisco password 7 032752180500
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
ssid CISCO_AP
speed basic-1.0 2.0 5.5 6.0 9.0 11.0 12.0 18.0 24.0 36.0 48.0 54.0
packet retries 128
station-role root access-point
rts retries 32
beacon dtim-period 100
world-mode dot11d country MX both
bridge-group 1
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.10
encapsulation dot1Q 10
no ip route-cache
bridge-group 10
bridge-group 10 subscriber-loop-control
bridge-group 10 block-unknown-source
no bridge-group 10 source-learning
no bridge-group 10 unicast-flooding
bridge-group 10 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
ssid CISCO_AP
speed basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0
packet retries 32
fragment-threshold 2338
station-role root
rts threshold 2338
rts retries 32
bridge-group 1
interface Dot11Radio1.10
no ip route-cache
bridge-group 10
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface FastEthernet0.10
no ip route-cache
bridge-group 10
interface BVI1
ip address 195.101.60.12 255.255.255.224
no ip route-cache
ip default-gateway 195.101.60.2
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
control-plane
bridge 1 route ip
line con 0
transport preferred all
transport output all
line vty 0 4
login local
transport input all
line vty 5 15
login
transport input all
end
ap#
Correct Answer
EvaldasOu Fri, 08/16/2013 - 10:06
debug dot11 events
debug dot11 packet
Abhishek Abhishek Mon, 09/02/2013 - 13:51
You do not require a license to operate radio equipment in the 2.4 GHz band where the Cisco Aironet WLAN equipment operates. As a result, other transmitters can broadcast on the same frequency that your WLAN uses.
A spectrum analyzer is the best tool to determine the presence of any activity on your frequency. The Carrier Busy test available in the Test menus of Cisco Aironet bridges functions as a substitute for this item. This test generates a rough display of activity on the different frequencies. If you suspect radio interference with transmission and reception on your WLAN, turn off the equipment that operates on the frequency in question and run the test. The test shows any activity on your frequency and the other frequencies on which the equipment can operate. You can thus determine if you want to change frequencies.
