Adding a Server
Aug 16th, 2013
I am new to MDS 9148 Switch & want to add a Server and want to share the EMC SAN, let me know if the specified commands looks good.
///Define Fcalias Name
fcalias name GICMSG02 vsan 101---------------------------------(Thats My Server)
member pwwn 50:01:43:80:12:0c:bd:5c
fcalias name BR_VNX_SPB0 vsan 101
member pwwn 50:06:01:68:3e:e0:0f:e6
fcalias name BR_VNX_SPA0 vsan 101
member pwwn 50:06:01:60:3e:e0:0f:e6
/////Create a Zone
zone name BR_VNX_SPB_GICMGT02 vsan 101
    member fcalias GICMSG02
    member fcalias BR_VNX_SPB0
zone name BR_VNX_SPA_GICMGT02 vsan 101
    member fcalias BR_VNX_SPA0
///Map Thats Zone to the VSAN
//zoneset name Production_Switch1 vsan 101
  //  member CX3221_A1_GICESX09_HBA1   Already in there & I will add the below commands
member BR_VNX_SPB_GICMGT02
member BR_VNX_SPA_GICMGT02
Overall Rating: 5 (1 ratings)
dynamoxxx Sat, 08/17/2013 - 20:44
  • Silver, 250 points or more
looks good
@dynamoxxx
imranraheel Mon, 08/19/2013 - 06:53
I have a brocade connected to HP C 700 and thats connected to Cisco 9148 . Do i have to make any changes on brocade as well ?
dynamoxxx Mon, 08/19/2013 - 20:52
HP blades servers with integrated brocade switches ?
@dynamoxxx
richbarb Mon, 08/19/2013 - 20:00
  • Cisco Employee,
If you are doing enhanced zoning in your mds fabrics you don't need do anything in the brocade fabric.
Richard
richbarb Mon, 08/19/2013 - 21:09
  • Cisco Employee,
One of them must be as npv (brocade or mds), if the zoning is in the mds...
Sent from Cisco Technical Support Android App
dynamoxxx Tue, 08/20/2013 - 04:33
on brocade it's not NPV, it's access gateway mode.
@dynamoxxx
richbarb Tue, 08/20/2013 - 04:44
  • Cisco Employee,
So, there is no option, one of them must be as npv and the other with npiv enabled.
dynamoxxx Tue, 08/20/2013 - 04:54
not necessarily, you could run brocade i native mode and use interop vsan on MDS.
@dynamoxxx
richbarb Tue, 08/20/2013 - 06:10
  • Cisco Employee,
Guys,
The interop mode was discontinued by brocade, to connect mds to brocade fabric you must run mds as npv mode.
Follow the reference:
http://www.brocade.com/downloads/documents/matrices/compatibility-matrix-fos-7x-mx.pdf
"NOTE: Cisco switches must be configured to Cisco N-Port Virtualizer (NPV) mode to connect to Brocade switches.
Cisco NP ports connect to Brocade F_Ports."
imranraheel Tue, 08/20/2013 - 06:44
Guys , i am fairly new in storage networking . How whould i be able to verify that which devioce is npv and which is with npiv enabled or access gateway.
On brocade i see the MDS swicth in the zone field
@dynamoxxx Yes HP is with Integrated Brocade switch.
dynamoxxx Tue, 08/20/2013 - 07:38
typicall with integrated switches that come with HP C-class blade enclosures, you put them in NPV mode if they are MDS 9124e or you put them into access gateway mode if they are Brocade 4024.  For either of those cases if your core switch is MDS, you need to enable NPIV.
Is this a brand new implementation that you are trying to setup ?
@dynamoxxx
imranraheel Tue, 08/20/2013 - 07:41
No its not new , everything is working , I just want to add another Server & SAN communication
dynamoxxx Tue, 08/20/2013 - 07:42
ok, then install operating system on the server, it will login to the fabric and do your zoning/array work.
@dynamoxxx
imranraheel Tue, 08/20/2013 - 07:45
You mean the below on MDS only
/////Create a Zone
edondurguti Sun, 08/25/2013 - 20:32
I'm adding a server too and I've been to exposed to MDS/fibre/storage just for a week, did some reading and I do understand alot of it.
I have one MDS swtich connected to UCS and EMC, we added two new servers in UCS I need to do zoning for those two servers. I have the idea of all commands, just as the ones above, i'm doing device alias instead of fcalias.
From my reading I know you have to activate the zoneset.
So.
Create zone
Add memebers
go to already created zoneset
add the zone created above
Activate zoneset
Will it dusrupt anything? I am running basic mode but there are no other switches connected to it.. just the UCS and EMC so there are no E ports all of them are N ports.
richbarb Sun, 08/25/2013 - 21:06
  • Cisco Employee,
Hello mate,
The zoning activate process is not disruptive to already active zone, unless if your modifications are not only incremental changes.
Richard
edondurguti Sun, 08/25/2013 - 21:12
Thanks for you reply Richard, not sure what you mean by  'not only incremental changes'
here's an example
zone name VMSRV012_fc0_EMC01_SPA0 vsan 250
    member pwwn 21:00:00:24:ff:48:a5:a1
    member pwwn 50:06:01:60:3e:a0:5a:c5
zoneset name MDSNAP_250_FAB-A vsan 250
    member VMSRV003_fc0_EMC01_SPA0
    member VMSRV003_fc0_EMC01_SPB1
    member VMSRV004_fc0_EMC01_SPA0
    member VMSRV004_fc0_EMC01_SPB1
    member VMSRV005_fc0_EMC01_SPA0
    member VMSRV005_fc0_EMC01_SPB1
    member VMSRV006_fc0_EMC01_SPA0
this is current
I'm trying to add
to
and then activate.
this should not delete or disrupt anything?
Thanks for your reply
richbarb Sun, 08/25/2013 - 21:18
  • Cisco Employee,
This is not disruptive change.
For example, would be disruptive if you try to change the entire zone for another.
edondurguti Sun, 08/25/2013 - 21:20
Thanks Mate,
I'm in the learning process of datacenter technologies and fiber :] coming from ethernet/routing/switching.
dynamoxxx Tue, 08/27/2013 - 22:08
if you noticed your sever needs to be zoned to at least one port on SPA and one port onSPB (each HBA), this is best practice for Clariion/VNX arrays.
@dynamoxxx
edondurguti Tue, 08/27/2013 - 22:14
Yes. The FC1 is added on vsan251. I have inherited the config.
Basically everything talks to everything. Do u have a best practice doc ? Id appretiate it
dynamoxxx Wed, 08/28/2013 - 14:17
i don't think it's documented anywhere but it's common knowledge for folks managing Clariion/VNX arrays.
@dynamoxxx
Trending Topics: Storage Networking
