Warning message
NTP time status
Aug 16th, 2013
We have a C40 running TC6.2 and under the web status page it does not show the NTP status in many cases....
On some systems it shows the IP address that is manually configured, but most its blank like the screen shot below.
I can connect SSH and do a "systemstools ntp" command and see all the NTP info I could want. (I masked out the IP addreses)
I can see the local NTP source (IP gateway address in our case) and the original clock source, etc, etc)
I would also like to see the NTP status added to the Diagnostics section to let us know if there is no NTP sync
Can someone tell me if there is a fix in the works to get the web NTP status to show the info that is available in the systemtools NTP command?
systemtools ntp
     remote           refid      st t when poll reach   delay   offset  jitter
127.127.1.0     LOCL            10 l    -   16    0    0.000    0.000   0.000
*xxx.xxx.138.1  xxx.xxx.214.229   3 u  152  256  377    1.207   -0.151   0.125
Current time in UTC is: Fri Aug 16 15:54:16 2013
Current time in EDT is: Fri Aug 16 11:54:16 2013
ahmashar Fri, 08/16/2013 - 22:48
  • Bronze, 100 points or more
I would suggest you open a TAC case and request this enhancement feature. As far as I know it's not on the product development pipeline or it's not on the high priority list.
thanks, Ahmad
juriss Mon, 08/19/2013 - 12:34
I turned this into a Service Request....
ahmashar Mon, 08/19/2013 - 12:51
Thank you for improving our product with the feature enhancement request via opening a case.
regards, Ahmad
