Warning message
Cisco877 proxyDNS intermittent problem
Answered Question
Aug 16th, 2013
Hi all
I was hoping someone would be able to shed some light on my current problem.
Got a Cisco 877W up and running on a PPPoE ADSL2+ connection with my ISP.
Router is set up as proxyDNS and the local workstations are configured to use the router as both gateway and DNS via DHCP.
After a router reboot everything is working as expected, however after 1 to 6 hours DNS resolution from the locally connected workstations (Windows 7 and other devices) stops working. I am fairly confident the problem is with the router (perhaps IOS), because if I change the DHCPs DNS server entries to my ISP DNS it works. If I change DNS to the router IP, resolution eventually fails. In other words:
THIS ALWAYS WORK
ip dhcp pool DHCP_LAN
   dns-server 111.118.175.56 (ISP DNS)
THIS WORK FOR A WHILE, BUT EVENTUALLY FAILS
   dns-server 192.168.50.3 (Router IP)
Troubleshooting examples from Router & Workstation + Router config provided below.
Any feedback is highly appreciated.
RUNNING CONFIGURATION
Current configuration : 4108 bytes
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug uptime
service timestamps log uptime
service password-encryption
service sequence-numbers
hostname 877gateway.org
boot-start-marker
boot-end-marker
no aaa new-model
dot11 ssid 877-WiFi
   authentication open
   authentication key-management wpa
   guest-mode
   wpa-psk ascii "removed"
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.50.1 192.168.50.10
   import all
   network 192.168.50.0 255.255.255.0
   default-router 192.168.50.3
ip dhcp pool QNAP219
   host 192.168.50.9 255.255.255.0
   client-identifier "removed"
ip dhcp pool X58A_N1
   host 192.168.50.51 255.255.255.0
ip dhcp pool X58A_N2
   host 192.168.50.52 255.255.255.0
ip name-server 111.118.175.56
ip name-server 118.127.33.48
username "removed" privilege 15 password "removed"
archive
log config
  hidekeys
bridge irb
interface ATM0
no ip address
ip route-cache flow
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
no snmp trap link-status
pvc 8/35
  pppoe-client dial-pool-number 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
no ip address
ip route-cache flow
encryption mode ciphers tkip
ssid 877-WiFi
speed basic-1.0 2.0 5.5 6.0 9.0 11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
no ip address
ip route-cache flow
bridge-group 1
interface Dialer0
ip address negotiated
ip access-group 101 in
no ip redirects
no ip unreachables
ip mtu 1492
ip nat outside
ip virtual-reassembly
encapsulation ppp
ip route-cache flow
dialer pool 1
dialer-group 1
no cdp enable
ppp pap sent-username "removed" password "removed"
ppp ipcp dns request
ppp ipcp route default
interface BVI1
ip address 192.168.50.3 255.255.255.0
ip access-group 102 in
ip nat inside
ip route-cache flow
ip tcp adjust-mss 1452
ip flow-cache timeout active 1
ip flow-export source Vlan1
ip flow-export version 9
ip flow-export destination 192.168.50.53 2048
no ip http server
no ip http secure-server
ip dns server
ip nat inside source list 1 interface Dialer0 overload
access-list 1 permit any
access-list 101 permit ip any any
access-list 102 permit ip any any
dialer-list 1 protocol ip permit
snmp-server community public RO
snmp-server ifindex persist
control-plane
bridge 1 route ip
line con 0
exec-timeout 0 0
logging synchronous
no modem enable
line aux 0
line vty 0 4
exec-timeout 0 0
password "removed"
logging synchronous
login local
scheduler max-task-time 5000
webvpn cef
end
ROUTER TROUBLESHOOTING
Show Version
ROM: System Bootstrap, Version 12.3(8r)YI2, RELEASE SOFTWARE
877gateway.org uptime is 16 hours, 57 minutes
System returned to ROM by reload
System image file is "flash:c870-adventerprisek9-mz.124-15.T.bin"
Cisco 877W (MPC8272) processor (revision 0x200) with 118784K/12288K bytes of memory.
DNS test from router (DNS always working from router)
877gateway.org#ping google.com
Translating "google.com"...domain server (111.118.175.56) [OK]
Sending 5, 100-byte ICMP Echos to 74.125.237.131, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 32/44/60 ms
877gateway.org#tracer google.com
Tracing the route to google.com (74.125.237.131)
  1 "removed"
  2 "removed"
  3 "removed"
  4 "removed"
  5 202.7.171.46 48 msec 52 msec 28 msec
  6 66.249.95.234 36 msec 112 msec 52 msec
  7 72.14.237.137 36 msec 28 msec 36 msec
  8 google.com (74.125.237.131) 32 msec 48 msec 28 msec
877gateway.org#
WORKSTATION (WIN7) TROUBLESHOOTING
Ethernet adapter "Local Area Connection" on PC
IPv4 Address
: 192.168.50.51(Preferred)
Subnet Mask
: 255.255.255.0
Default Gateway
: 192.168.50.3
DHCP Server
: 192.168.50.3
DNS Servers
: 192.168.50.3
NetBIOS over Tcpip
: Enabled
DNS troubleshooting from workstation (DNS stops working after a while)
C:\>ping -n 2 google.com
Ping request could not find host google.com. Please check the name and try again
C:\>tracert -d google.com
Unable to resolve target system name google.com.
C:\>nslookup
DNS request timed out.
    timeout was 2 seconds.
Default Server:  UnKnown
Address:  192.168.50.3
> server 192.168.50.3
Default Server:  [192.168.50.3]
> google.com
*** Request to [192.168.50.3] timed-out
Correct Answer by cadet alain about 4 years 2 days ago
Can you do a packet capture on the router WAN and LAN interfaces when working and when failing as well at look at the dns cache with sh  hosts command on the router
For packet capture use this:http://routerjockey.com/2011/02/14/ios-embedded-packet-capture/
Alain
Overall Rating: 5 (1 ratings)
johnlloyd_13 Sat, 08/17/2013 - 09:07
  • Blue, 1500 points or more
hi,
could you add the ip domain-lookup command and try again?
CiscoPurist Sat, 08/17/2013 - 10:03
Thanks for the suggestion, I already did.
Interesting part is, it's not showing up in the running-config but it is enabled. If I do a "no ip domain lookup" it shows.
Entry from running config with "ip domain lookup" enabled
Entry from running config "ip domain lookup" not enabled
no ip domain lookup
Unfortunately I already tested with this command enabled/not enabled and did reboots, but this is not the cause of my problem.
Even my monitoring software is indicating a problem with the routers DNS service
Perhaps someone knows the relevant debug commands I could use to troubleshoot router dns?
CiscoPurist Sat, 08/17/2013 - 20:26
Hi Alain
I hit the "Correct Answer" button by mistake, is there anyway I can undo that to not mark my question answered?
Regarding your link, it says:
Since IOS 12.4(20)T Cisco has made Embedded Packet Capture
My current IOS version is:
877gateway.org#monitor ?
  event-trace  Control event tracing
  processes    Monitor processes
I think I have a newer IOS version available and I migth do an update, since I am eager to find out what is causing this problem.
Anyway appreciate the feedback. I will get back to you when I have some solid info.
