convert AP to LAP via Cisco prime infrastructure failed
Aug 18th, 2013
START: Detailed logging started at -> 08.19.2013_03.03.07
INFO: TELNET to device 10.34.60.7 done.
INFO: Privilege level is equal to 15.
INFO: Setting vty line completed.
INFO: Dumped Environmental variables.
INFO: AP is supported for Upgrade process
INFO: IOS version is greater than or equal to 12.3(7)JA.
INFO: AP has MIC installed already.
INFO: Station role is root.
INFO: DNS and Domain name configured.
INFO: Mac address of device is 00:21:d8:36:f9:3c
INFO: Completed Dot11Radio0 shutting.
INFO: Device set up done and time configured on device.
INFO: Run-config dumped.
INFO:  Gateway 10.34.60.1
INFO: Hostname AARAPA01
INFO: Starts loading recovery image, takes time based on link speed.
ERROR: Device Response :: examining image...
Loading c1130-rcvk9w8-tar.124-21a.JA2.tar from 10.102.1.74 (via BVI1): !
extracting info (273 bytes)
ERROR: Image is not a valid IOS image archive.
archive download: takes 1 seconds
ERROR: Image Loading FAILURE.
INFO: Un-shut radio 1 done.
END: Migration Process Failure: Image Loading Failure.
Amjad Abdullah Sun, 08/18/2013 - 23:02
  • Red, 2250 points or more
Make sure you are using a good image (check teh md5 checksum and make sure it matches the one posted in Cisco site. try to download a new image if needed).
Make sure the image you download is for the AP model you use.
Amjad
Rating useful replies is more useful than saying "Thank you"
Related Content
