Warning message
Dual-band Omni External Antenna
Answered Question
Aug 18th, 2013
Can someone recommend me a dual-band omni antenna for connection to a Cisco 3600? For use indoors.
I have found this:
http://www.cisco.com/en/US/docs/wireless/antenna/installation/guide/ant2544v4m-r.html
But it seems a bit overkill for what I need. All I want is a small profile indoor antenna I can connect to the AP.
I require the antenna so that the AP can be mounted vertically with the antenna sticking out the top so as to create the correct coverage pattern
Correct Answer by Leo Laohoo about 4 years 1 day ago
http://www.intermec.com/public-files/product-profiles/en/CiscoAntennasAccessories_spec_web.pdf
Hi Kashif,
This document link you've posted is already OUTDATED.   All the antenna's in this PDF are valid up to the AP1250.  The antenna required for the 3600, as what is stated by the OP, is totally different.
Antennas for the newer generation of Cisco APs which are dual-band radios, go here.
Overall Rating: 5 (1 ratings)
Leo Laohoo Sun, 08/18/2013 - 22:25
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Go here:  Antenna Product Portfolio for Cisco Aironet 802.11n Access Points
Look at Table 5, 6 & 7.
If "low profile" is what you are looking for, then the ceiling-mounted AIR-ANT2524V4C-R is your best bet.
Correct Answer
Leo Laohoo Mon, 08/19/2013 - 15:20
  • Hall of Fame,
    2017 LAN, Wireless
Hi Kashif,
kaaftab Mon, 08/19/2013 - 15:23
  • Silver, 250 points or more
you are right n thxs for the update
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
