Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1927652members
1240570discussions
Community Activity
10mb connections
Hello,On the newer switches with 2.5/5gb ports how do you handle devices that only work with a 10mb NIC?We have a HVAC controller that only has a 10mb NIc on it so the switch doesn’t detect it. Is there a device that will convert down to 10mb like a ...
pollardt3 by Level 1
  • 0 Views
  • 0 replies
Client status locked in "Web Auth Pending" on WLC 9800-40
Hello all,   I'm having an issue with clients connected on my Guest SSID configured with Web Authentication Splash Page. Basically by today (NO CHANGES NOR ACTIVITIES WERE DONE) all the clients which are trying to connect to this SSID cannot reach th...
Simone C by Level 1
  • 27 Views
  • 1 replies
One-way Audio following IP Address Change
I've recently inherited a new network as part of beginning a new job.  Historically, my exposure to voice is pretty limited.  Without getting into the details of what lead to it, as it's not relevant, after performing a reset on an 8851, the phone gr...
robo764 by Level 1
  • 0 Views
  • 0 replies
vfmc-7.4 cannot deploy ovf
Dear TeamI have downloaded the vfmc for esxi 7.4.X and 7.3X but i cannot deploy in VMware after deployment its retturn "operating system not found"any ideaRegards
Changing wsa data ip
Hi all,We had WSA appliance and we are migrating appliance to virtual environment.We have configured new WSA and tested and its working fine and now we are planning to move it to LIve so we are planning to change the data ip.of new virtual WSA to the...
SIB9 by Level 1
  • 5 Views
  • 0 replies
Resolved! A question about MAC addresses for access points
Can anybody tell me what exactly is the difference between the radio MAC address vs the ethernet and Wi-Fi mac addresses? What is the purpose of the radio MAC address? Apparently, wireless access points don't just have an ethernet and Wi-Fi MAC, but ...
Jibroni by Level 1
  • 149 Views
  • 4 replies
redundancy in core layer
hi guys . i have a network with below topology. In the core layer, I want to have redundancy, which means that if the main core switch of my network has a problem, the backup switch will automatically enter the circuit. What method is there?
chpmotry by Level 1
  • 84 Views
  • 6 replies
