08-19-2013 04:51 PM
I have a query regarding using multiple WCCP redirect lists on the 6500 chassis (Sup720-10G) running IOS 12.2(33).
How does the 6500 handle the processing of the ACLs when both service groups are assigned to the same interface in the same direction?
Will both redirect ACL's be processed accordingly?
Or will the 6500 dump traffic if it hits a "deny any any" statement in the first ACL before processing the second ACL where the permit statement will be?
09-23-2013 06:18 AM
Did you ever recieve a response on this?
Kind Regards,
MTR
09-25-2013 04:14 PM
Hi MTR,
I raised a TAC case and the TAC engineer decided to lab it before giving an answer.
Based on some internal documentation and the lab, the 6500 will process each WCCP service in numerical order (lowest first, eg: 51 and will stop at first ACL match).
As long as the ACL's are in the right order and do not overlap it works without issues.
The TAC tested both L2 and GRE redirection with no issues.
Cheers,
Zig
01-12-2014 05:49 AM
The reason is unlike in ISRs there is a command "ip wccp check service all" which means that process all wccp service groups on the interfaces on the basis of priority until a match is found. However, with 6500/switching platforms, this command is not available but the behavior is enabled by default. 6500 does not consider the group priority but it looks at the group number instead... least numbered service group is considered first.
12-03-2020 03:18 AM - edited 12-03-2020 03:19 AM
A question is raised for both cases (ISR -> Priority or Cat6500 -> Group Number):
Even if we manipulate Priority/Group number in a way that we "reorder" the ACLs to be checked, won't the implicit "deny ip any any" of the first ACL in order, match ALL traffic? How will the checking continue to the other ACL?
Unless this implicit deny in WCCP config is not considered a "match". Or even better, no kind of "deny" line is taken as a "match".
Any thoughts please?
