Warning message
CUCMBE 6000 LIC
Answered Question
Aug 21st, 2013
Hi Support,
I have installed CUCM/CUC 6000 (UCS C200 M2) Exsi.4.1.0  i use ova taplates for both now i need to install the .lic which MAC should i chose i didnt understand do i have to configure manually this is the network output for CUCM what if i reinstall these MAC will remain same???
DHCPdisabled
StatusUp
IP Address10.10.5.5
IP Mask255.255.255.000
Link Detectedyes
Queue Length1000
MTU1500
MAC Address00:0c:29:5c:f8:7e
License MAC6a3cacbd1a51
RX Bytes356175
RX Packets2637
RX Errors0
RX Dropped0
RX Overrun0
RX Multicast0
TX Bytes2445227
TX Packets1088
TX Errors0
TX Dropped0
TX Carrier0
TX Collisoins
For Unity Connection
DHCPdisabled
StatusUp
IP Address10.10.5.6
Link Detectedyes
Queue Length1000
MTU1500
MAC Address00:0c:29:9c:04:07
License MAC0a849e42d4e7
RX Bytes277824
RX Packets2636
RX Errors0
RX Dropped0
RX Overrun0
RX Multicast0
TX Bytes1594214
TX Packets878
TX Errors0
TX Dropped0
TX Carrier0
TX Collisoins0
Sheraz
Correct Answer by Chris Deren about 4 years 11 hours ago
1. See this thread:
https://supportforums.cisco.com/thread/2177324
2. this is OVA for provisioning manager, if you want to install and use it this the OVA template for it.
HTH, please rate all useful posts!
Chris
Correct Answer by Chris Deren about 4 years 12 hours ago
Use the License MAC 6a3cacbd1a51 for all licensing with this version, once you go to version 9+ it becomes irrelevant due to ELM implementation.
HTH,
Chris
Correct Answer by Jaime Valencia about 4 years 12 hours ago
Then you use the respective license MAC to license each system
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
Overall Rating: 4.5 (4 ratings)
sheraz butt Wed, 08/21/2013 - 09:34
Hi Sir,
Thanks for  quick reply we  ordered all the lic for 6K CUCM/CUC are installed up and running EXSi version 4.1 vSphare 4.1 registered version (UCS C200 M2 rack mount server )
CUCM 8.6.2a
CUC    8.6.2a
Regards ,
Sheraz
Correct Answer
Chris Deren Wed, 08/21/2013 - 09:49
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
HTH,
Chris
sheraz butt Wed, 08/21/2013 - 10:12
Hello Sir ,
First of all thanks you very much for help okay i will use CUCM  License MAC for CUCM and Unity License MAC for CUC.
I have only 2 questions now your help will be appreciated.
1) If something happend or crash software and i need to reinstall the CUCM and CUC on same server from scratch the LIC MAC will change or remain same for both product CUCM/CUC 8.6.2a or i can backup and restore? .
2) what is this file for (cupm_8_6_linux_vmware.ova) i received with the bundle  i need to install this or its okay to contnue because i install this and its asking for username and password.
Please correct me.
Thanks In Advance
Sheraz
Correct Answer
Chris Deren Wed, 08/21/2013 - 10:15
  • Hall of Fame,
1. See this thread:
Chris
