ACE30 License on ACE20
Joao Wiens
Level 4
Level 4
I have a customer who want's to upgrade the ACE20 Throughput from 1K TPS to at least 5K TPS or more. The upgrade License for the ACE20 are in EOS, and the ACE30 is in AEOS. Is it possible to use the Upgrade License from the ACE30 on the ACE20? For example the ACE30-MOD-UPG1=?
Jorge Bejarano
Level 4
Level 4
Joao,
Each license is designed to be used for a specific device, then the answer is: not
Then you cannot use a license for an ACE4710 in an ACE 20 or ACE 30 or any combination like that
Here you have some details about licenses in ACE30 and ACE 20:
http://www.cisco.com/en/US/prod/collateral/modules/ps2706/ps6906/product_bulletin_c25_632385.html
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/ace/vA2_3_0/configuration/administration/guide/license.html
Jorge
