Warning message
C881W-E-K9 flash memory
Aug 22nd, 2013
Hello
I' m have C881W-A-K9 factory defaul this device have flash:, flash:0:, flash:1:.  Then flash format from ROMMON, only 1 flash device "flash".  How back flash partition again. (factory default).
Router boot from ROMMON
ifs_open failed, path flash:1:/env_vars errno 2574
*Aug 22 21:52:23.131: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
*Aug 22 21:52:23.131: %CRYPTO-6-GDOI_ON_OFF: GDOI is OFF
*Aug 22 21:52:30.763: %SECONDCORE-5-BOOTSTAGE: ROMMON on 2nd core UP
*Aug 22 21:52:30.867: %SECONDCORE-5-BOOTSTAGE: AP-BOOTLOADER on 2nd core UP
sh ver
isco IOS Software, C800 Software (C800-UNIVERSALK9-M), Version 15.3(3)M, RELEAS
E SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Mon 22-Jul-13 05:25 by prod_rel_team
ROM: System Bootstrap, Version 15.1(4r)M, RELEASE SOFTWARE (fc1)
router uptime is 1 minute
System returned to ROM by reload at 21:49:34 UTC Thu Aug 22 2013
System image file is "flash:c800-universalk9-mz.SPA.153-3.M.bin"
Cisco C881W-E-K9 (revision 1.0) with 363596K/29619K bytes of memory.
Processor board ID FCZ1718C2CY
5 FastEthernet interfaces
1 Gigabit Ethernet interface
1 terminal line
1 Virtual Private Network (VPN) Module
1 cisco Embedded AP (s)
DRAM configuration is 32 bits wide
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash (Read/Write)
paolo bevilacqua Thu, 08/22/2013 - 15:09
  • Hall of Fame,
    Founding Member
Disregard rommon.
Your router only have one filesystem flash:
Leo Laohoo Thu, 08/22/2013 - 15:35
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
sh flash:?
flash: flash:0: flash:1:
Ok, if you so insist.
Try the commands "sh flash1:".  You'll see it'll come up with an error message.
yurepavlovske Fri, 08/23/2013 - 13:15
sh flash:1:
router#sh flash:1:
-#- --length-- -----date/time------ path
1         1883 Aug 22 2013 17:53:38 +04:00 config.txt
3      7598080 Mar 22 2013 07:21:54 +04:00 ap802-k9w7-tar.124-25d.JAX1.tar
4      3266560 Mar 22 2013 07:22:10 +04:00 ap802-rcvk9w8-tar.124-23c.JA2X
5            0 Aug 14 2013 15:38:12 +04:00 ap802-k9w7-mx.152-4.JA1
6            0 Aug 14 2013 15:38:12 +04:00 ap802-k9w7-mx.152-4.JA1/html
7            0 Aug 14 2013 15:38:12 +04:00 ap802-k9w7-mx.152-4.JA1/html/level
8            0 Aug 14 2013 15:38:12 +04:00 ap802-k9w7-mx.152-4.JA1/html/level/1
9          563 Aug 14 2013 15:38:14 +04:00 ap802-k9w7-mx.152-4.JA1/html/level/1/appsui.js
10         512 Aug 14 2013 15:38:14 +04:00 ap802-k9w7-mx.152-4.JA1/html/level/1/back.shtml
11        5032 Aug 14 2013 15:38:14 +04:00 ap802-k9w7-mx.152-4.JA1/html/level/1/cookies.js
12       20125 Aug 14 2013 15:38:16 +04:00 ap802-k9w7-mx.152-4.JA1/html/level/1/forms.js
13       16560 Aug 14 2013 15:38:18 +04:00 ap802-k9w7-mx.152-4.JA1/html/level/1/sitewide.js
14        3220 Aug 14 2013 15:38:18 +04:00 ap802-k9w7-mx.152-4.JA1/html/level/1/stylesheet.css
15       25812 Aug 14 2013 15:38:20 +04:00 ap802-k9w7-mx.152-4.JA1/html/level/1/config.js
16        1020 Aug 14 2013 15:38:20 +04:00 ap802-k9w7-mx.152-4.JA1/html/level/1/popup_capabilitycodes.shtml.gz
17        1862 Aug 14 2013 15:38:22 +04:00 ap802-k9w7-mx.152-4.JA1/html/level/1/filter.js.gz
18        1459 Aug 14 2013 15:38:22 +04:00 ap802-k9w7-mx.152-4.JA1/html/level/1/filter_vlan.js.gz
19        1793 Aug 14 2013 15:38:24 +04:00 ap802-k9w7-mx.152-4.JA1/html/level/1/filter_mac_ether.js.gz
20         962 Aug 14 2013 15:38:24 +04:00 ap802-k9w7-mx.152-4.JA1/html/level/1/security.js.gz
21         959 Aug 14 2013 15:38:24 +04:00 ap802-k9w7-mx.152-4.JA1/html/level/1/vlan.js.gz
22        4286 Aug 14 2013 15:38:26 +04:00 ap802-k9w7-mx.152-4.JA1/html/level/1/ssid.js.gz
23        2084 Aug 14 2013 15:38:26 +04:00 ap802-k9w7-mx.152-4.JA1/html/level/1/network-if.js.gz
24         988 Aug 14 2013 15:38:28 +04:00 ap802-k9w7-mx.152-4.JA1/html/level/1/dot1x.js.gz
25         957 Aug 14 2013 15:38:28 +04:00 ap802-k9w7-mx.152-4.JA1/html/level/1/stp.js.gz
26        5653 Aug 14 2013 15:38:30 +04:00 ap802-k9w7-mx.152-4.JA1/html/level/1/ap_assoc.shtml.gz
27        3907 Aug 14 2013 15:38:30 +04:00 ap802-k9w7-mx.152-4.JA1/html/level/1/ap_event-log.shtml.gz
28        7048 Aug 14 2013 15:38:32 +04:00 ap802-k9w7-mx.152-4.JA1/html/level/1/ap_home.shtml.gz
29        3565 Aug 14 2013 15:38:32 +04:00 ap802-k9w7-mx.152-4.JA1/html/level/1/ap_network-if.shtml.gz
30        3880 Aug 14 2013 15:38:32 +04:00 ap802-k9w7-mx.152-4.JA1/html/level/1/ap_network-map.shtml.gz
31        3697 Aug 14 2013 15:38:34 +04:00 ap802-k9w7-mx.152-4.JA1/html/level/1/ap_services.shtml.gz
32        2888 Aug 14 2013 15:38:34 +04:00 ap802-k9w7-mx.152-4.JA1/html/level/1/ap_system-sw.shtml.gz
33        3834 Aug 14 2013 15:38:36 +04:00 ap802-k9w7-mx.152-4.JA1/html/level/1/ap_contextmgr.shtml.gz
34           0 Aug 14 2013 15:38:36 +04:00 ap802-k9w7-mx.152-4.JA1/html/level/1/images
35        2035 Aug 14 2013 15:38:36 +04:00 ap802-k9w7-mx.152-4.JA1/html/level/1/images/ap_title_appname.gif
36        1211 Aug 14 2013 15:38:38 +04:00 ap802-k9w7-mx.152-4.JA1/html/level/1/images/apps_button.gif
37        1171 Aug 14 2013 15:38:38 +04:00 ap802-k9w7-mx.152-4.JA1/html/level/1/images/apps_button_1st.gif
38         318 Aug 14 2013 15:38:40 +04:00 ap802-k9w7-mx.152-4.JA1/html/level/1/images/apps_button_cbottom.gif
39        1206 Aug 14 2013 15:38:40 +04:00 ap802-k9w7-mx.152-4.JA1/html/level/1/images/apps_button_current.gif
40         878 Aug 14 2013 15:38:40 +04:00 ap802-k9w7-mx.152-4.JA1/html/level/1/images/apps_button_endcap.gif
41         333 Aug 14 2013 15:38:42 +04:00 ap802-k9w7-mx.152-4.JA1/html/level/1/images/apps_button_encap_last.gif
42         386 Aug 14 2013 15:38:42 +04:00 ap802-k9w7-mx.152-4.JA1/html/level/1/images/apps_button_last.gif
43        1177 Aug 14 2013 15:38:44 +04:00 ap802-k9w7-mx.152-4.JA1/html/level/1/images/apps_button_nth.gif
44         869 Aug 14 2013 15:38:44 +04:00 ap802-k9w7-mx.152-4.JA1/html/level/1/images/apps_leftnav_dkgreen.gif
45         879 Aug 14 2013 15:38:46 +04:00 ap802-k9w7-mx.152-4.JA1/html/level/1/images/apps_leftnav_green.gif
--More--
cdybenko#sh flash:1:
--More--
yurepavlovske Fri, 08/23/2013 - 13:26
I agree with Paolo and Leo
C881W-A-K9 have only one flash memory, but IOS look this one flash memory like flash:, flash:0:, flash:1:. After format factory default Cisco C881W flash. IOS look this flah memory like only one flash:.  How i m can come back setting to factory default, IOS look this flash memory like flash:, flash:0:, flash:1:.
paolo bevilacqua Fri, 08/23/2013 - 13:32
  • Hall of Fame,
    Founding Member
Again: your router has only one flash filesystem. Not two.
Leo Laohoo Fri, 08/23/2013 - 20:43
  • Hall of Fame,
    2017 LAN, Wireless
sh flash:1:
That's the wrong syntax.  It means that you have a directory called "1".
Can you please post the output to the following commands:
1.  dir; and
2.  sh version
Leo Laohoo Thu, 08/22/2013 - 15:14
  • Hall of Fame,
    2017 LAN, Wireless
I agree with Paolo.
Your router does not behave like a 2960S/X, 3750 or 3850 switch.  There's only one flash.  The only time you use the "0:" and/or "1:" is when you start using USB flash.  Now that's a different matter all together.
And your router does not behave like an old ASA where you need to partition your flash.
So exactly, what are you trying to do?
