Cisco Prime ver 1.3 issue
Aug 22nd, 2013
Hi @all
today i´d tried to login at my Cisco Prime interface. After i´d tried to browse to the device center i get an error. See picture.
The last config i did was to configure Radius setting. But i´d tested it and threre it works fine ... Any idea
There was an error while parsing and rendering the content. (Tried to register widget with id==dGroupOS but that id is already registered)
THX Mario
Another error is when i´d tried to click on Administration->SystemSettings->Datadeduplication i get this error
There was an error while parsing and rendering the content. (Tried to register widget with id==tableSP_xwtTableGlobalToolbar_refreshButton but that id is already registered)
Overall Rating: 5 (1 ratings)
MarioLieb Fri, 08/23/2013 - 00:18
Hi guys
new Information ... with Firefox it works ... with Chrome and IE not ....
Fredrik Hjelm Fri, 08/23/2013 - 01:16
I have the same problem. It seems that Chorme is updated to Version 29.0.1547.57 m, and along with it these problems came.
We tested on a PC that ran version 28-something and this problem was not present.
FF works.
Fredrik Hjelm Fri, 08/23/2013 - 01:24
I also get various other error-msg:
There was an error while parsing and rendering the content. (Tried to register widget with id==officeExtendApDialog but that id is already registered)
There was an error while parsing and rendering the content. (Object #has no method 'getAttribute')
Vinod Arya Fri, 08/23/2013 - 01:39
  • Cisco Employee,
Google has broke some of the features with latest version of chrome (v29) and hence CPI is having some issues. You can still run older Chrome version or use other browsers.
It is still being worked upon for fix.
jjurkiew Wed, 08/28/2013 - 10:39
  • Cisco Employee,
This is wholly a problem introduced by Google.  Chrome 29 changed something in their dom traversal code used by QuerySelectorAll and/or in their actual DOM structure properties.   This broke the Dojo JavaScript Toolkit critical API: dojo.query.  The query code started to return TEXT nodes instead of just DOM Elements.  This is incorrect behavior and as such has caused the dom/template parser of Dojo to break while instantiating various types of widgets; primarily things such as the dijit Select control.  This has a ripple effect of breaking/failing page loads with random errors.  The most common error seen is some type of 'getAttribute' error.
You can refer to this Dojo bug on the subject:
https://bugs.dojotoolkit.org/ticket/17400
Cisco is currently working to patch the products affected by this .  In the meantime the only options are to downgrade Chrome and Chrome Frame back to 28, or to use FireFox.
k.aumell Sat, 10/26/2013 - 12:57
I have applied the patch per the instructions, and it said "patch applied successfully",but when I do a "show version", it has not added the line about the update.
Any thoughts?
andypenning Tue, 09/10/2013 - 07:27
There is a patch for this. Below is info on the 1.3 patch:
Description:Apply this patch over existing Prime Infrastructure 1.3.0.20 to fix the issue introduced in Google Chrome 29 build, which broke Dojo Toolkits query interface.
Release:1.3.0
Release Date:04/Sep/2013
File Name:PI_1_3_0_20-Update.1.12.CSCui77571-2.tar.gz
Size:0.13 MB (134938 bytes)
MD5 Checksum:d56011daa798def923e34c9ec40196bd
MarioLieb Wed, 09/11/2013 - 22:19
Hello
it works !!!
There is also a Patch for 1.4 available this Patch works also ...
j.hellstern Mon, 09/16/2013 - 01:27
didn't work for me. I just installed the patch on CISCO Prime 1.3
Still the same error: IE / Chrome Frame 29 shows it. Firefox is working.
Wayne Swanson Mon, 09/16/2013 - 07:03
Fails in IE and Chrome.  Home page works on both (dashboard will render),
but with IE, Operate >device work center will either fail with a "error parsing and rendering content.  (Object # has no method "get attribute"),
or in Chrome - it just won't render the main frame.
Firefox still works, but reports an 'unsupported browser' error on Prime's splash / login screen.
j.hellstern Tue, 09/17/2013 - 03:27
Yes, I cleared the browser cache. But this did not help for IE.
jjurkiew Mon, 09/16/2013 - 07:07
  • Cisco Employee,
Did you clear your browser cache after patching the server?   If you don't clear your browser cache, it is likely the browser is still loading the broken version from its local cache.
Sincerely,
-- Jared Jurkiewicz
Wayne Swanson Mon, 09/16/2013 - 07:38
/facepalm
Yes, that seems to have resolved that issue for Chrome.  I have not tested IE yet.
Marcel Kamenz Mon, 10/07/2013 - 00:23
Same issue here.
Applied the patch, cleared browser cache.
So I tested it again:
Test-Client 1 - Windows 8 x64:
- IE10:
- Firefox 24:
Works but reeeeeeally slow......sometimes a meassage like "process ...dojo...not work" pops up.
Chrome 30:
Test-Client 2 - Windows 8 x32
- IE10:
Chrome 30:
So Cisco......what I have to do now? There are some users that want to use the CPI .
Marcel Kamenz Sun, 10/27/2013 - 23:47
I had some troubble with the CPI too.
All started with the Update from NCS to CPI.
The final solution was the update to CPI 2.0.0.0.294.
Now the CPI works very well and fast too .
alois.heilmaier... Fri, 11/01/2013 - 12:39
I also had the same issue.
Just installed Patch PI_1_3_0_20-Update.4-16.tar.gz
Problem gone for
Firefox 25.0 and IE10 with Chrom Frame Plugin (unsupported Plugin by the way)
Problem was still there for Chrome Version 30.0.1599.101 until I cleared all the cached data.
But until now I have not done much on testing.
Best Regards
Alois
bauti1428 Fri, 11/08/2013 - 07:13
how long did it take you to install the patch
PI_1_3_0_20-Update.4-16.tar.gz? Do you have to stop NCS or either way it will work? Its been like this for about 15 minutes.
CPRIME/admin# patch install PI_1_3_0_20-Update.4-16.tar.gz ftpbkup
Save the current ADE-OS running configuration? (yes/no) [yes] ? yes
Generating configuration...
Saved the ADE-OS running configuration to startup successfully
Initiating Application Patch installation...
alois.heilmaier... Sun, 11/10/2013 - 01:53
I could not remember anymore how long it took, because I was in trouble with a crash of ncs.
But I have done a backup before patching this took a long time about 1hour.
I do always copy the file to a repository on local disk. I start ftp from my management station to the ftp-dir on ncs an do a put, I do not use a remote mounted file system via ftp on ncs because I had a slow ftp throughput....
Stopping or starting ncs takes always about 30 minutes, sometimes starting did not work at the firts start.
ncs/admin# backup ncs1-3-20_2013-11-1 repository
% Creating backup with timestamped filename: ncs1-3-20_2013-11-1-131101-1843.tar.gpg
Patch installation, maybe took only a few minutes, but I had not memorized it. I do only have a logg of that, but also without stopping ncs manually.
ncs/admin# patch install PI_1_3_0_20-Update.4-16.tar.gz
Patch successfully installed
ncs/admin# sh ver
Cisco Application Deployment Engine OS Release: 2.0
ADE-OS Build Version: 2.0.1.038
ADE-OS System Architecture: x86_64
Copyright (c) 2005-2010 by Cisco Systems, Inc.
All rights reserved.
Hostname: ncs
Version information of installed applications
Cisco Prime Network Control System
Version : 1.3.0.20
Patch: Cisco Prime Network Control System Version: Update.4.16
ncs/admin#
GERALD LECAILLIER Wed, 11/13/2013 - 06:59
I updated two different PI 1.3.0.20 > I got the same problems:
- in the release notes they said it shoult took 15 to 20 minutes...
- one hour later I decided to abort with CTRL-C, I stop services, restart server, restart services
- then the update took less than 20 minutes and now it's working
I had this problem twice...
