Warning message
Cisco PI 1.3 Insert boot command
Aug 23rd, 2013
I would distribute a new ios image to Cat2960CG-8TC-L.
I have enabled "insert boot command" and Reboot Device: "Immediately.
Copy image to the device:     OK
Reboot device:                     OK but with old image.
Job Status:
Validating device distribution context        SUCCESS                 -
Backup of current running image c2960c405ex-universalk9-mz.122-55.EX3.bin                      -                 DISABLED
Distributing image c2960c405ex-universalk9-mz.150-2.SE4.bin using protocol TFTP     SUCCESS                 -
Rebooting device with Image c2960c405ex-universalk9-mz.150-2.SE4.bin"                   SUCCESS                 -                    (Reboots with old 12.2(55) image)
So, i don't know why Cisco PI doesn't insert the boot command for the new ios image, and reboot the device with the new image.
Cisco PI:
Version : 1.3.0.20
Patch: Cisco Prime Network Control System Version: Update-1_12_for_version_1_3_0_20
Can anyone help me?
Best regards
Bernhard
Vlad Vlaicu Sat, 08/31/2013 - 03:04
  • Cisco Employee,
Hi Bernhard,
You might want to check if on the device is already a boot command defined. In this case, due to the order of operation, the old IOS will be preffered.
If this doesn't help, you can try a packet capture and see if PI actually sets the command.
Best regards,
Vlad
NMS Team
Krakow, Poland
Cisco TAC
Related Content
